path: root/board/pn62
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-02Moved initialization of PCNET Ethernet controller to board_eth_init()Ben Warren
Affected boards: PN62 sc520_cdp Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-03-12[new uImage] Add new uImage format support to autoscript routineMarian Balakowicz
autoscript() routine is updated to accept second argument, which is only used for FIT images and provides a FIT subimage unit name. autoscript() routine callers must now pass two arguments. For non-interactive use (like in cmd_load.c, cmd_net.c), new environment variable 'autoscript_uname' is introduced and used as a FIT subimage unit name source. autoscript command accepts extended syntax of the addr argument: addr:<subimg_uname> Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc824x linker scripts (3 of 4)Grant Likely
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-08-08Initial revisionwdenk
