path: root/board/pm854
2008-01-09Reworked FSL Book-E TLB macros to be more readableKumar Gala
The old macros made it difficult to know what WIMGE and perm bits were set for a TLB entry. Actually use the bit masks for these items since they are only a single bit. Also moved the macros into mmu.h out of e500.h since they aren't specific to e500. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_*_ADDR as the base of the registers instead of getting it via &immap. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Stop using immap_t for guts offset on 85xxKumar Gala
In the future the offsets to various blocks may not be in same location. Move to using CFG_MPC85xx_GUTS_ADDR as the base of the guts registers instead of getting it via &immap->im_gur. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-10-11Merge with http://opensource.freescale.com/pub/scm/u-boot-85xx.git#for_wdWolfgang Denk
2006-10-11* Fix a bunch of compiler warnings for gcc 4.0Matthew McClintock
Signed-off-by: Matthew McClintock <msm@freescale.com>
2005-08-12Remove stale file entryWolfgang Denk
2005-08-05Merge with /home/wd/git/u-boot/jon_loeligerWolfgang Denk
2005-08-05Minor fixes to PM854 boardWolfgang Denk
Patch by Josef Wagner, 03 Aug 2005
2005-07-25* Patch by Jon Loeliger, 2005-07-25Jon Loeliger
Move the TSEC driver out of cpu/mpc85xx as it will be shared by the upcoming mpc83xx family as well.
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
2005-04-03Patches by Josef Wagner, 29 Oct 2004:wdenk
- Add support for MicroSys CPU87 board - Add support for MicroSys PM854 board
