path: root/board/pm520
2005-08-02Coding style cleanupWolfgang Denk
2005-07-30Implement h/w sector protection status synchronization at boot.Wolfgang Denk
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
