path: root/board/pm520
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-09-09disk-on-chip: remove duplicate doc_probe declarationJean-Christophe PLAGNIOL-VILLARD
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04Remove obsolete mpc5xxx linker scripts (1 of 3)Grant Likely
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-01-13Fix 28F256J3A support on PM520 boardWolfgang Denk
(without bank-switching only 32 MB can be accessed)
2005-12-29Add support for 28F256J3A flah (=> 64 MB) on PM520 boardWolfgang Denk
2005-08-02Coding style cleanupWolfgang Denk
2005-07-30Implement h/w sector protection status synchronization at boot.Wolfgang Denk
The code is provided for, and was tested on, the Yukon/Alaska and PM520 boards only. A bug in flash_real_protect() for the Yukon board was fixed by adding a function that tells if two banks are on one flash chip.
2005-05-05Major upate of JFFS2 code; now in sync with snapshot of MTD CVS ofwdenk
March 13, 2005); new configuration options CONFIG_JFFS2_LZO and CONFIG_JFFS2_LZARI are added. Both are undefined by default.
2005-04-21Fix bug in the SDRAM initialization code for canmb, IceCube andwdenk
PM520 boards. Fix PHY address for canmb board.
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
