path: root/board/phytec
2013-08-15am33xx: Stop using PHYS_DRAM_1 defineTom Rini
We defined PHYS_DRAM_1 to 0x80000000 (start of DRAM) and then used this for CONFIG_SYS_SDRAM_BASE. But then we kept on referencing PHYS_DRAM_1 in other places. Change to directly setting CONFIG_SYS_DRAM_BASE and then using that name in code. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15ARM: AM33xx: Move s_init to a common placeHeiko Schocher
s_init has the same outline for all the AM33xx based board. So making it generic. This also helps in addition of new Soc with minimal changes. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-08-15ARM: AM33xx: Cleanup dplls dataLokesh Vutla
Locking sequence for all the dplls is same. In the current code same sequence is done repeatedly for each dpll. Instead have a generic function for locking dplls and pass dpll data to that function. This is derived from OMAP4 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-06-18arm, am33xx: move uart soft reset code to common placeHeiko Schocher
move uart soft reset code to common place and call this function from board code, instead of copy and paste this code for every board. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> [trini: Fix igep0033 build, remove 'regval' on pcm051] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-18arm, am33xx: move rtc32k_enable() to common placeHeiko Schocher
move rtc32k_enable() to common place so all am33xx boards can use it. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-06-05am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.cTom Rini
We need to call the save_omap_boot_params function on am33xx/ti81xx and other newer TI SoCs, so move the function to boot-common. Only OMAP4+ has the omap_hw_init_context function so add ifdefs to not call it on am33xx/ti81xx. Call save_omap_boot_params from s_init on am33xx/ti81xx boards. Reviewed-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08pcm051: Enable DDR PHY dynamic power down bitLars Poeschel
This is done already for am335x in 59dcf970d11ebff5d9f4bbbde79fda584e9e7ad4 and also applies for pcm051. It powers down the IO receiver when not performing read which helps reducing the overall power consuption in low power states (suspend/standby). Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-03-24am33xx: refactor emif4/ddr to support multiple EMIF instancesMatt Porter
The AM33xx emif4/ddr support closely matches what is need to support TI814x except that TI814x has two EMIF instances. Refactor all the emif4 helper calls and the config_ddr() init function to use an additional instance number argument. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: convert defines from am33xx-specific to generic namesMatt Porter
Eliminate AM33xx specific names to prepare for TI814x support within AM33xx-land. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-18am33xx: pcm051: Remove wp pin mux for sd-cardLars Poeschel
The pcm051 does not have the wp pin connected to the sd-card socket. Therefore remove the pinmux for the pin. The was a carry-over from the am335x evm code. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-02-07am33xx: Drop gpio0_7_pin_mux from phytec pcm051Tom Rini
This mux is not currently used and appears to be a carry-over from the am335x evm code. Acked-by: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
2012-07-29doc: cleanup - move board READMEs into respective board directoriesWolfgang Denk
Also drop a few files referring to no longer / not yet supported boards. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Jason Jin <jason.jin@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-23Coding Style cleanup; update CHANGELOG.Wolfgang Denk
2009-07-10board support patch for phyCORE-MPC5200B-tinyJon Smirl
Add support for the Phytec phyCORE-MPC5200B-tiny. Code originally from Pengutronix.de. Created CONFIG_SYS_ATA_CS_ON_TIMER01 define for when IDE CS is on Timer 0/1 Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca>
