path: root/board/phytec
2019-06-11imx: Extend PCL063 support for phyCORE-i.MX6ULL SOMParthiban Nallathambi
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063) with eMMC on SoM. CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 38C Reset cause: POR Model: Phytec phyBOARD-i.MX6ULL-Segin SBC Board: PHYTEC phyCORE-i.MX6ULL DRAM: 256 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial@02020000 Out: serial@02020000 Err: serial@02020000 Net: FEC0 Working: - Eth0 - i2C - MMC/SD - eMMC - UART (1 & 5) - USB (host & otg) Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-06-11ARM: dts: i.MX6ULL: U-Boot specific dts for u-boot, dm-splParthiban Nallathambi
u-boot,dm-spl property is specific to U-Boot, so created one for i.MX6ULL platforms. Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
2019-04-13pcm052: bk4: Add board_phy_config() for BK4 to setup ksz8081 phyLukasz Majewski
BK4 requires setup of 50MHz reference clock for its KSZ8081 PHY devices. Signed-off-by: Lukasz Majewski <lukma@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-04-13pcm052: mac: Provide board specific imx_get_mac_from_fuse() functionLukasz Majewski
This commit introduces the board specific function to read fused mac address. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: board: Add code to setup LED default statesLukasz Majewski
As one has moved to DM based LEDs, this code is required to setup the default state. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: bk4: sdcard: Add support for SD card booting/recoveryLukasz Majewski
This code allows reusing the default u-boot as in the late board init, the default envs are restored and proper recovery scripts executed. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: board: Remove in-board setup code (it is now replaced by DM setup)Lukasz Majewski
This commit cleans up the pcm052.c file to remove dead code after moving to DTS and DM. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: board: cosmetic: Add copyright notice to pcm052.cLukasz Majewski
2019-04-13pcm052: board: vybrid: Update the board name for BK4 deviceLukasz Majewski
This commit provides distinction between PCM052 and BK4. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: board: Remove "m4go" command as it is superseded by "bootaux"Lukasz Majewski
The "m4go" provides exactly the same functionality as the IMX generic "bootaux" command. Remove it to not duplicate the code. Signed-off-by: Lukasz Majewski <lukma@denx.de>
2019-04-13pcm052: board: Do not enable I2C2 code in the board fileLukasz Majewski
As the I2C2 clock is now enabled in the generic clock code, we can remove this code from a board file. Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2019-01-28imx: Add PHYTEC phyBOARD-i.MX6UL-SeginMartyn Welch
Port for the PHYTEC phyBOARD-i.MX6UL-Segin single board computer. Based on the PHYTEC phyCORE-i.MX6UL SOM (PCL063). CPU: Freescale i.MX6UL rev1.2 528 MHz (running at 396 MHz) CPU: Industrial temperature grade (-40C to 105C) at 44C Reset cause: POR Board: PHYTEC phyCORE-i.MX6UL I2C: ready DRAM: 256 MiB NAND: 512 MiB MMC: FSL_SDHC: 0 In: serial Out: serial Err: serial Net: FEC0 Working: - Eth0 - i2C - MMC/SD - NAND - UART (1 & 5) - USB (host & otg) Signed-off-by: Martyn Welch <martyn.welch@collabora.com>
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-11-06MAINTAINERS: Add missing boards and config entriesTom Rini
As part of my usual round of build testing, output about missing MAINTAINERS information was not logged, and thus often overlooked. Correct that mistake by ensuring that I log the output of genboardscfg.py every time. As part of that, address a number of missing MAINTAINERS entires. In the case of a missing file, I have put the original submitter down. In the rest of the cases I have added the config (and sometimes relevant header file) to the existing set of file globs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-05rockchip: phycore: Read configuration EEPROM & set ethaddr in late initWadim Egorov
Read SoM information from EEPROM and set ethaddr in late init. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-29pfla02: Fix RAM detection and support 1 bank SOMStefano Babic
In case of 2 banks, the address space of the first CS must be defined and not let to the higher value. Add support for SOM with a single bank of RAM. It was tested with i.MX6Q modules in the following configurations: - 2 Banks, 4 GB - 2 Banks, 1 GB - 1 Bank, 1 GB Signed-off-by: Stefano Babic <sbabic@denx.de>
2017-08-28imx: imx6: Move gpr_init() function to soc.cBreno Lima
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D, MX6Q and MX6QP processors move it to the soc.c file. Signed-off-by: Breno Lima <breno.lima@nxp.com> Acked-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-08-16Merge git://www.denx.de/git/u-boot-imxTom Rini
Update pfla02 for setenv changes and PHYLIB/etc migration to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-02mx6: Add support for Phytec pfla02 (NAND)Stefano Babic
Add support for Phytec pfla02, equipped with NAND. CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz) CPU: Automotive temperature grade (-40C to 125C) at 31C Reset cause: POR I2C: ready DRAM: 1 GiB NAND: 2048 MiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 SF: Detected n25q128 with page size 256 Bytes, erase size 64 KiB, total 16 MiB In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Stefan Christ <s.christ@phytec.de> CC: Stefan Müller-Klieser <S.Mueller-Klieser@phytec.de> CC: Christian Hemp <C.Hemp@phytec.de>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-11rockchip: Add basic support for phyCORE-RK3288 SoM based carrier boardWadim Egorov
The phyCORE-RK3288 is a SoM (System on Module) containing a RK3288 SoC. The module can be connected to different carrier boards. It can be also equipped with different RAM, SPI flash and eMMC variants. The Rapid Development Kit option is using the following setup: - 1 GB DDR3 RAM (2 Banks) - 1x 4 KB EEPROM - DP83867 Gigabit Ethernet PHY - 16 MB SPI Flash - 4 GB eMMC Flash Add basic support for the PCM-947 carrier board, a RK3288 based development board made by PHYTEC. This board works in a combination with the phyCORE-RK3288 System on Module. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-12pcm058: Fix unused variable warningsTom Rini
The variable nfc_pads is only referenced when CONFIG_CMD_NAND is set, add a gaurd. The variable gpio_pads is never referenced, drop it. The variable usdhc4_pads are only referenced when we do not have CONFIG_CMD_NAND set and we are not doing an SPL build, modify the existing guard. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-19ARM: vf610: move to standard arch/board approachStefan Agner
Move Freescale/NXP Vybrid to a standard arch/board approach, similar to what has been done to i.MX 6 earlier in commit 89ebc82137be ("ARM: mx6: move to a standard arch/board approach"). Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-02-08pcm052: fix DDR initialization sequenceAlbert ARIBAUD \(3ADEV\)
The sequence erroneously launched the DDR controller initialization before the pad muxing was done, causing DRAM size computation to hang. Configuring the pads first then launching DDR controller initialization prevents the DRAM hanging. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-10-26imx: s/docs\/README.imximage/doc\/README.imximage/gJagan Teki
Fixed typo for doc/README.imximage on respective imximage.cfg files. Cc: Tom Rini <trini@konsulko.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2016-10-06pcm052: add new BK4r1 target based on PCM052 SoMAlbert ARIBAUD \(3ADEV\)
2016-10-06pcm052: allow specifying onboard DDR size in configsAlbert ARIBAUD \(3ADEV\)
PCM052 SoMs may be equipped with various sizes of DDR. Keep default of 256MB; new PCM052-based targets will specify their actual DDR size. Linux command line is auto-adjusted to DDR size. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-10-06pcm052: add 'm4go' commandAlbert ARIBAUD \(3ADEV\)
Add the 'm4go' command to pcm052-based targets. It loads scatter file images. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-07-12mx6: Add Phytec PCM058 i.MX6 QuadStefano Babic
Add Phytec-i.MX6 SOM with NAND Support: - 1GB RAM - Ethernet - SPI-NOR Flash - NAND (1024 MB) - external SD - UART Signed-off-by: Stefano Babic <sbabic@denx.de> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-02vf610: add support for Phytec PCM052Albert ARIBAUD \(3ADEV\)
Devices supported are: - NFC (NAND FLASH) - MMC - QSPI (SPI NOR FLASH) - I2C (only bus 2) - I2C RTC - I2C EEPROM - FEC Patch-series: 2 - remove useless CONFIG_SYS_SPD_BUS_NUM from config - remove include of config_cmd_default.h - remove duplicate CONFIG_CMD_NET Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-02-24kconfig: remove unneeded dependency on !SPL_BUILDMasahiro Yamada
Now CONFIG_SPL_BUILD is not defined in Kconfig, so "!depends on SPL_BUILD" and "if !SPL_BUILD" are redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-12dm: omap3: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
