path: root/board/phytec/pcm051/board.c
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05usb: musb-new: CONFIG_MUSB prefix replacement with CONFIG_USB_MUSBPaul Kocialkowski
USB-related options are usually prefixed with CONFIG_USB and platform-specific adaptation for the MUSB controller already have a CONFIG_USB_MUSB prefix, so this switches all MUSB-related options to a CONFIG_USB_MUSB prefix, for consistency. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-04drivers: net: cpsw: add support to have phy address from cpsw platform dataMugunthan V N
Some platforms like AM437x have different EVMs with different phy addresses, so this patch adds support for passing phy address via cpsw plaform data. Also renamed phy_id to phy_addr so better understanding of the code. Reviewed-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> [trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335 pengwyn boards] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-18ARM: AM33xx+: Update ioregs to pass different valuesLokesh Vutla
Currently same value is programmed for all ioregs. This is not the case for all SoC's like AM4372. So adding a structure for ioregs and updating in all board files. And also return from config_cmd_ctrl() and config_ddr_data() functions if data is not passed. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> [trini: Fixup dxr2, cm_t335, adapt pcm051 rev3] Signed-off-by: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-04am33xx: Stop modifying certain EMIF4D registersTom Rini
Based on the definitive guide to EMIF configuration[1] certain registers that we have been modifying (and are documented registers) should be left in their reset values rather than modified. This has been tested on AM335x GP EVM and Beaglebone White. [1]: http://processors.wiki.ti.com/index.php/AM335x_EMIF_Configuration_tips Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Javier Martinez Canillas <javier@dowhile0.org> Cc: Heiko Schocher <hs@denx.de> Cc: Lars Poeschel <poeschel@lemonage.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Matt Porter <matt.porter@linaro.org>
2013-12-04pcm051: Support for revision 3Lars Poeschel
Phytec sells revision or version 3 of pcm051. It is labeled 1358.3 on the board. The difference for u-boot is that is has other DDR3 RAM on it: 1 x MT41K256M16HA125E instead of 2 x MT41J256M8HX15E on revisions 1 and 2. Both configurations are 512 MiB. Configure your u-boot build with pcm051_rev3 for the new RAM and pcm051_rev1 for the old RAM configuration. Board revision 2 has to use pcm051_rev1 also. Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-10-07pcm051/igep0033: Supply bd_ram_ofs for cpsw driverLars Poeschel
Since 2bf36ac638ab2db9f0295aa47064976eeebf80c1 the BD ram address is not hardcoded inside cpsw driver any more. Platforms have to supply their bd_ram_ofs in the platform data to the driver. This commit does this for pcm051 and igep0033 boards. Tested-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-08-28arm, am33xx: add defines for gmii_sel_register bitsHeiko Schocher
Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
2013-08-15am33xx: Stop using PHYS_DRAM_1 defineTom Rini
We defined PHYS_DRAM_1 to 0x80000000 (start of DRAM) and then used this for CONFIG_SYS_SDRAM_BASE. But then we kept on referencing PHYS_DRAM_1 in other places. Change to directly setting CONFIG_SYS_DRAM_BASE and then using that name in code. Signed-off-by: Tom Rini <trini@ti.com>
2013-08-15ARM: AM33xx: Move s_init to a common placeHeiko Schocher
s_init has the same outline for all the AM33xx based board. So making it generic. This also helps in addition of new Soc with minimal changes. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Tom Rini <trini@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-08-15ARM: AM33xx: Cleanup dplls dataLokesh Vutla
Locking sequence for all the dplls is same. In the current code same sequence is done repeatedly for each dpll. Instead have a generic function for locking dplls and pass dpll data to that function. This is derived from OMAP4 boards. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2013-06-18arm, am33xx: move uart soft reset code to common placeHeiko Schocher
move uart soft reset code to common place and call this function from board code, instead of copy and paste this code for every board. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Acked-by: Tom Rini <trini@ti.com> [trini: Fix igep0033 build, remove 'regval' on pcm051] Signed-off-by: Tom Rini <trini@ti.com>
2013-06-18arm, am33xx: move rtc32k_enable() to common placeHeiko Schocher
move rtc32k_enable() to common place so all am33xx boards can use it. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Matt Porter <mporter@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Tom Rini <trini@ti.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
2013-06-05am33xx/omap: Move save_omap_boot_params to omap-common/boot-common.cTom Rini
We need to call the save_omap_boot_params function on am33xx/ti81xx and other newer TI SoCs, so move the function to boot-common. Only OMAP4+ has the omap_hw_init_context function so add ifdefs to not call it on am33xx/ti81xx. Call save_omap_boot_params from s_init on am33xx/ti81xx boards. Reviewed-by: R Sricharan <r.sricharan@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2013-04-08pcm051: Enable DDR PHY dynamic power down bitLars Poeschel
This is done already for am335x in 59dcf970d11ebff5d9f4bbbde79fda584e9e7ad4 and also applies for pcm051. It powers down the IO receiver when not performing read which helps reducing the overall power consuption in low power states (suspend/standby). Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2013-03-24am33xx: refactor emif4/ddr to support multiple EMIF instancesMatt Porter
The AM33xx emif4/ddr support closely matches what is need to support TI814x except that TI814x has two EMIF instances. Refactor all the emif4 helper calls and the config_ddr() init function to use an additional instance number argument. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-24am33xx: convert defines from am33xx-specific to generic namesMatt Porter
Eliminate AM33xx specific names to prepare for TI814x support within AM33xx-land. Signed-off-by: Matt Porter <mporter@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-07pcm051: Add support for Phytec phyCORE-AM335xLars Poeschel
The board is named pcm051 and has this hardware: SOC: TI AM3359 DDR3-RAM: 2x MT41J256M8HX-15EIT:D 512MiB ETH 1: LAN8710AI SPI-Flash: W25Q64BVSSIG RTC: RV-4162-C7 I2C-EEPROM: CAT32WC32 NAND: MT29F4G08_VFPGA63 PMIC: TPS65910A3 LCD Supported: UART 1 MMC/SD ETH 1 USB I2C SPI Not yet supported: NAND RTC LCD Signed-off-by: Lars Poeschel <poeschel@lemonage.de> [trini: Add #define CONFIG_PHY_ADDR 0 to config] Signed-off-by: Tom Rini <trini@ti.com>
