path: root/board/pdm360ng
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-24mpc5121: add support for PDM360NG boardAnatolij Gustschin
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh. Signed-off-by: Michael Weiss <michael.weiss@ifm.com> Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
