path: root/board/pcs440ep/flash.c
2007-07-11[PCS440EP] - Show on the DIAG LEDs, if the SHA1 check failedHeiko Schocher
- now the Flash ST M29W040B is supported (not tested) - fix the "led" command - fix compile error, if BUILD_DIR is used Signed-off-by: Heiko Schocher <hs@denx.de>
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2006-06-02Minor cleanupWolfgang Denk
2006-06-02Add support for PCS440EP boardStefan Roese
Patch by Stefan Roese, 02 Jun 2006
