path: root/board/pcippc2
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
2002-10-31Initial revisionwdenk
2002-08-26Initial revisionwdenk
2002-04-01Initial revisionwdenk
2002-01-26Initial revisionwdenk
2002-01-15Initial revisionwdenk
