path: root/board/pcippc2
2013-03-11ppc: Remove PCIPPC2 and PCIPPC6 boardsStefan Roese
These boards seem to be unmaintained for quite some time. So lets remove support for them completely. This also cleans up some common drivers/files. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Guillaume Alexandre <guillaume.alexandre@gespac.ch> Acked-by: Wolfgang Denk <wd@denx.de>
2012-10-17serial: Use default_serial_puts() in driversMarek Vasut
Replace the in-place ad-hoc implementation of serial_puts() within the drivers with default_serial_puts() call. This cuts down on the code duplication quite a bit. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from serial driversMarek Vasut
Remove the support for not-CONFIG_SERIAL_MULTI part from serial port drivers and some board files. Since CONFIG_SERIAL_MULTI is now enabled by default, that part is a dead code. Remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: powerpc: Implement CONFIG_SERIAL_MULTI into sconsole serial driverMarek Vasut
Implement support for CONFIG_SERIAL_MULTI into sconsole serial driver. This driver was so far only usable directly, but this patch also adds support for the multi method. This allows using more than one serial driver alongside the sconsole driver. Also, add a weak implementation of default_serial_console() returning this driver. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2010-11-2774xx_7xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-19Fix boards broken after removal of legacy NAND and DoC supportWolfgang Denk
Commit 2419169f removed support for legacy NAND and disk on chip but missed to update the code for a few boards. This patch fixes the resulting build issues. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
2002-10-31Initial revisionwdenk
2002-08-26Initial revisionwdenk
