path: root/board/pcippc2/pcippc2.c
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-01Patch by Kenneth Johansson, 30 Jun 2003:wdenk
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-11-04Patch by Guillaume Alexandre,, 04 Nov 2002:wdenk
Improve PCI access on 32-bits Compact PCI bus Adjust VFD initialization on TRAB Cleanup RRvision video code
