path: root/board/pb1x00
2008-06-05[MIPS] Kill unused <version.h> inclusionsShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-05-30[MIPS] <asm/mipsregs.h>: Update coprocessor register access macrosShinya Kuribayashi
2008-04-18Use jr as register jump instructionShinya Kuribayashi
Current assembler codes are inconsistent in the way of register jump instruction usage; some use jr, some use j. Of course GNU as allows both usages, but as can be expected from `Jump Register' the mnemonic `jr' is more intuitive than `j'. For example, Linux doesn't have `j <reg>' usage at all. Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-11-18pb1x00 board: Fix u16 status declaration when PCMCIA is definedJean-Christophe PLAGNIOL-VILLARD
2007-11-17[MIPS] pb1000: Replace obsolete memsetup.S with lowlevel_init.SShinya Kuribayashi
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
2007-11-17Fixed mips_io_port_base build errors.Jean-Christophe PLAGNIOL-VILLARD
This patch has been sent on: - 29 Sep 2007 Although mips_io_port_base is currently a part of IDE command, it is quite fundamental for MIPS I/O port access such as in[bwl] and out[bwl]. So move it to MIPS general part, and introduce `set_io_port_base()' from Linux. This patch is triggered by multiple definition of `mips_io_port_base' build error on gth2 (and tb0229 also needs this fix.) board/gth2/libgth2.a(gth2.o): In function `log_serial_char': /home/skuribay/devel/u-boot.git/board/gth2/gth2.c:47: multiple definition of `mips_io_port_base' common/libcommon.a(cmd_ide.o):/home/skuribay/devel/u-boot.git/common/cmd_ide.c:712: first defined here make: *** [u-boot] Error 1 Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Remove duplicated .sdata sectionShinya Kuribayashi
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
