path: root/board/pb1x00/u-boot.lds
2007-11-17[MIPS] u-boot.lds: Cleanup __u_boot_cmd_{start,end}Shinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2007-10-21[MIPS] u-boot.lds: Define _gp in a standard mannerShinya Kuribayashi
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Fix __got_start and __got_endShinya Kuribayashi
Ensure that __got_start points to top of the `.got', and __got_end points to bottom as well, so that we never fail to count num_got_entries. Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2007-10-21[MIPS] u-boot.lds: Remove duplicated .sdata sectionShinya Kuribayashi
2005-09-25Add support for AMD's Pb1x00 eval board;Wolfgang Denk
add MII routines to the au1x00 ethernet driver; add USB ohci driver (work in progress) Patch by Thomas Sailer, 20 Jan 2005
