path: root/board/pandora
2020-06-11arm: Remove omap3_pandora_defconfig boardJagan Teki
OF_CONTROL, DM_SPI and other driver model migration deadlines are expired for this board. Remove it. Acked-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2020-05-18common: Drop linux/delay.h from common headerSimon Glass
Move this uncommon header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2020-05-18common: Drop init.h from common headerSimon Glass
2018-09-10omap3: pandora: Enable DM_SERIALGrazvydas Ignotas
This patch enables DM_SERIAL for the pandora board. Verified that the default kernel can still be booted with this. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2017-05-15mmc: replace CONFIG_GENERIC_MMC with CONFIG_MMCMasahiro Yamada
Now CONFIG_GENERIC_MMC and CONFIG_MMC match for all defconfig. We do not need two options for the same feature. Deprecate the former. This commit was generated with the sed script 's/GENERIC_MMC/MMC/' and manual fixup of drivers/mmc/Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-10-22omap-common: Common function to display die id, replacing omap3-specific versionPaul Kocialkowski
This introduces omap_die_id_display to display the full die id. There is no need to store it in an environment variable, that no boot script is using anyway. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@konsulko.com>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-10-23omap3/am33xx: mux: fix several checkpatch issuesIgor Grinberg
Fix the following checkpatch issues: CHECK: No space is necessary after a cast \#39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> \#284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C ERROR: space required after that ',' (ctx:VxV) \#446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat <raph@8d.com> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Nishanth Menon <nm@ti.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefan Roese <sr@denx.de>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-05-10twl4030: make twl4030_i2c_write_u8 prototype consistentNishanth Menon
u-boot standard i2c register write prototype is i2c_reg_write(u8 addr, u8 reg, u8 val) twl4030_i2c_write_u8(u8 addr, u8 val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_write_u8(u8 addr, u8 reg, u8 val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-05-15OMAP3: pandora: revise GPIO configurationGrazvydas Ignotas
Update pandora's GPIO setup code with these changes: - convert to gpiolib - set up dual voltage GPIOs to match supply of 1.8V by clearing VMODE1 - add GPIO_IO_PWRDNZ configuration for DM3730 variation of pandora (required to enable GPIO 126, 127, and 129 I/O cells in DM3730) - add wifi reset pulse as recommended by wifi chip's manufacturer - drop configuration of GPIOs that u-boot doesn't need Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2012-05-15OMAP3: pandora: pin mux updates for DM3730 board variantGrazvydas Ignotas
DM3730 needs some additional pin mux configuration for GPIOs 126-129 to work, add it. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2011-09-04OMAP3: pandora: Use generic MMC driverTom Rini
Switch from the legacy omap3 mmc driver to the new generic omap hsmmc driver. This patch is based on the work done for Beagle, etc. Signed-off-by: Tom Rini <trini@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-04omap: fix gpio related build breaksAneesh V
Signed-off-by: Aneesh V <aneesh@ti.com> Acked-by: Dirk Behme <dirk.behme@googlemail.com>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-19OMAP3: pandora: fix relocation and init memoryGrazvydas Ignotas
map Fix the build breakage introduced by the recent relocation and memory layout changes for ARM. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-06-08OMAP3: pandora: enable battery backup capacitorGrazvydas Ignotas
Pandora has a capacitor connected as backup battery, which allows retaining RTC for some time while main battery is removed. Enable backup battery charge function to charge that capacitor. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04pandora: don't enable VAUX3, VDAC and VPLL2 regulatorsGrazvydas Ignotas
These regulators are not needed to start the kernel and only cause "incomplete constraints" warnings from kernel, so don't turn them on to save power. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-11-24OMAP3: pandora: fix booting without serial attachedGrazvydas Ignotas
When the board is booted without serial cable attached (which is how most of them will be used) UART RX is left floating and sometimes picks noise, which interrupts countdown and enters U-Boot prompt instead of booting the kernel. Fix this by setting up internal pullup on UART RX pin. This does not prevent serial from working as the internal pullup is weak. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05omap3: move the other boards to board/Jean-Christophe PLAGNIOL-VILLARD
