path: root/board/palmtc
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2012-10-22mmc: pxa: Flip over the remaining boards to pxa_mmc_genericMarek Vasut
Some of the boards still used the old PXA_MMC driver instead of the new generic one. Use the new one instead so the old can be removed and the generic MMC framework can be properly used. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andy Fleming <afleming@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2011-12-06PXA: Rename pxa_dram_init to pxa2xx_dram_initMarek Vasut
2011-12-06PXA: Squash extern pxa_dram_init()Marek Vasut
2010-10-22PXA: palmtc: Fix for relocMarek Vasut
2010-10-19PXA: Palm Tungsten|C SupportMarek Vasut
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
