path: root/board/palmtc/Makefile
2010-10-22PXA: palmtc: Fix for relocMarek Vasut
2010-10-19PXA: Palm Tungsten|C SupportMarek Vasut
This patch adds support for the Palm Tungsten|C PXA255 board. The support includes: - LCD - MMC - UART - NOR Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
