path: root/board/overo
2014-06-19omap3: overo: Select fdtfile for expansion boardAsh Charles
The u-boot Overo board actually supports both Overo (OMAP35xx) and Overo Storm (AM/DM37xx) COMs with a range of different expansion boards. This provides a mechanism to select the an appropriate device tree file based on the processor version and, if available, the expansion board ID written on the expansion board EEPROM. To match the 3.15+ kernels, fdtfile names have this format: "omap3-overo[-storm]-<expansion board name>.dtb" By default, we use "omap3-overo-storm-tobi.dtb". Signed-off-by: Ash Charles <ashcharles@gmail.com> Conflicts: include/configs/omap3_overo.h
2014-05-23OMAP3: overo: add some Gumstix expansion boardsAsh Charles
Add EEPROM ID switches for Alto35, Arbor43C, Stagecoach, Thumbo, and Turtlecore Gumstix Overo expansion boards. Signed-off-by: Ash Charles <ash@gumstix.com>
2014-05-23Add Board Revision for Wireless chipAsh Charles
Gumstix Overo COMs with board revision 0x4 use a different Wifi and Bluetooth module: Wi2Wi's W2CBW0015. No other code changes are required in u-boot---just handling of this particular board revision. Signed-off-by: Ash Charles <ashcharles@gmail.com>
2014-03-04mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-08-15omap: overo: Use 200MHz SDRC timings for revision 1, 2 & 3 boardsAsh Charles
Gumstix uses 200Mhz RAM on revision 1, 2 & 3 COMs, so use 200MHz timings rather than 165MHz. Based on 6cf8bf44b1f8550e12f7f2a16e01890e5de8443d Signed-off-by: Ash Charles <ashcharles@gmail.com>
2013-08-15omap: overo: update support for Micron 1GB POPSteve Sakoman
2013-04-08asm/omap_gpmc.h: consolidate common definesAndreas Bießmann
arch/arm/include/asm/arch-am33xx/omap_gpmc.h and arch/arm/include/asm/arch-omap3/omap_gpmc.h are almost the same, consolidate the common parts into a new header. Introduce a new asm/omap_gpmc.h which defines the command part and pulls in the architecture specific one. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Tom Rini <trini@ti.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-12-10Pass sdrc timing values through board_sdrc_timings structurePeter Barada
Instead of passing individual registers by value to board_get_mem_timings, pass a board_mem_timings structure pointer for the board files to fill in. Pass same structure pointer to write_sdrc_timings. This saves about 90 bytes of space in SPL. Signed-off-by: Peter Barada <peter.barada@logicpd.com>
2012-09-27omap-common: SPL: Add CONFIG_SPL_DISPLAY_PRINT / spl_display_print()Tom Rini
Only omap4/5 currently have a meaningful set of display text and overo had been adding a function to display nothing. Change how this works to be opt-in and only turned on for omap4/5 now. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15ARM:OMAP+:MMC: Add parameters to MMC initJonathan Solnit
Add parameters to the OMAP MMC initialization function so the board can mask host capabilities and set the maximum clock frequency. While the OMAP supports a certain set of MMC host capabilities, individual boards may be more restricted and the OMAP may need to be configured to match the board. The PRG_SDMMC1_SPEEDCTRL bit in the OMAP3 is an example. Signed-off-by: Jonathan Solnit <jsolnit@gmail.com>
2012-01-16overo: add SPL supportAndreas Müller
* implementation based on ti beagleboard/omap3evm * timing data and i2c workaround for revision 0 boards taken from x-loader * run-tested with overo revision 0 and 1 / boot from NAND and SDcard * run-tested with x-loader Signed-off-by: Andreas Müller <schnitzeltony@gmx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-16board/overo/overo.c: replace printf with one argument by putsAndreas Müller
2011-10-27omap: Don't use gpio_free to change direction to inputJoe Hershberger
gpio_free() should not have the side effect of setting the line to input since this prevents the gpio command from being able to set a line as output. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27OMAP3: overo: Move ethernet CS4 configuration to execute based on board idPhilip Balister
By moving the CS4 configuration into the board specific configuration, it is left free for custom carrier boards. The USRP-E1XX series uses CS4 to control access to an FPGA, so without this patch the device driver cannot claim CS4. Signed-off-by: Philip Balister <philip@opensdr.com> Tested-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap: overo: Disable pull-ups on camera PCLK, HS and VS signalsSteve Sakoman
The level shifters used on the Caspa camera module have a 4k output impedance. Combined with the 100uA pull-up resistors in the OMAP3, this raises the ground level to 400mV. Adding crosstalk between the pixel clock and the HS/VS signals on the flat cable (a ground line in between would have been nice), logic 0 levels can raise up to 650mV. This exceeds the camera input pins VIL maximum voltage. This change suggested-by Laurent Pinchart Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-10-27omap: overo: Configure mux for gpio10Steve Sakoman
This pad was previously configured for sysclkout_1. This patch changes the configuration to gpio_10 to reduce radiated noise from the 26Mhz clock, as well as make the pin more generally useful. Signed-off-by: Steve Sakoman <steve@sakoman.com> Acked-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30overo: Set IEN on GPMC_CLK to support synchronous clocking.Philip Balister
Without this change CS's configured for synchronous clocking cannot read data. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30OMAP3: Overo: Update GPMC timing for ethernet chipPhilip Balister
The existing timing does not quite meet the minimum requirements in the LAN9221 datasheet. The timing in this patch solves problems noticed on some parts. The patch also combines the CS configuration for the overo and igep0020 boards per request. Signed-off-by: Philip Balister <philip@opensdr.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap: gpio: Adapt board files to use generic APISanjeev Premi
This patch contains updates the sources in the board files to use the generic API. Signed-off-by: Sanjeev Premi <premi@ti.com>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-04ARMV7: OMAP3: Add expansion board detection for OveroSteve Sakoman
Overo expansion boards contain an i2c eeprom to identify themselves. This patch adds code to read and parse the eeprom contents. It prints the expansion board name and revision and modifies environment variables as appropriate. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17ARMV7: OMAP3: Implement relocation for OveroSteve Sakoman
This patch fixes the build breakage introduced by the recent relocation changes for ARMV7 Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-10-17ARMV7: OMAP4: Use generic mmc driver on OveroSteve Sakoman
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Steve Sakoman <steve@sakoman.com>
2010-09-08ARMV7: OMAP: Overo: Autodetect presence/absence of transceiver on mmc2Steve Sakoman
An upcoming version of Overo uses a Wifi/BT module with 1.8V signaling, eliminating the need for an external transceiver to handle the level shifting. This patch detects whether an external transceiver is present and adjusts the pinmux settings as appropriate. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP: Configure Overo's second network chipSteve Sakoman
Confiures GPMC timings for both chips and also configures pinmux for GPIO_65, which is used as the interrupt signal for the second chip Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP: Add board revision detection for OveroSteve Sakoman
The latest Overo COM modules encode their revision number on GPIOs 115, 113, and 112. All boards to date have no pullups on these pins and hence appear as revision 0. This patch reads and prints the revision information. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-09-08ARMV7: OMAP: Enable input driver on Overo's MMC1_CLK and MMC3_CLK pinmux setupSteve Sakoman
This patch modifies the pinmux setup for MMC1_CLK and MMC3_CLK to enable the input driver. MMC2_CLK was already properly configured. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12Overo GPMC registersScott Ellis
Use appropriate GPMC timings for the LAN9221 controller on the Gumstix Overo expansion boards not the values in arch-omap3/mem.h which are for a different ethernet controller. Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-10-13TI: OMAP3: Overo Tobi ethernet supportOlof Johansson
Add setup for ethernet on Tobi, allowing kernel/ramdisk to be loaded over tftp. This also refactors the smc911x driver to allow for detecting when the chip is missing. I.e. the detect_chip() function is called earlier and will abort gracefully when the Chip ID read returns all 1's. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05omap3: move the other boards to board/Jean-Christophe PLAGNIOL-VILLARD
