path: root/board/overo
2010-02-12Overo GPMC registersScott Ellis
Use appropriate GPMC timings for the LAN9221 controller on the Gumstix Overo expansion boards not the values in arch-omap3/mem.h which are for a different ethernet controller. Signed-off-by: Scott Ellis <scott@jumpnowtek.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-01-04TWL4030: make LEDs selectable for twl4030_led_init()Grazvydas Ignotas
Not all boards have both LEDs hooked, so enabling both on boards with single LED will just waste power. Make it possible to choose LEDs by adding argument to twl4030_led_init(). Using this turn on only LEDB for pandora, leave both LEDs on for all other boards, as it was before this patch. Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
2009-10-13TI: OMAP3: Overo Tobi ethernet supportOlof Johansson
Add setup for ethernet on Tobi, allowing kernel/ramdisk to be loaded over tftp. This also refactors the smc911x driver to allow for detecting when the chip is missing. I.e. the detect_chip() function is called earlier and will abort gracefully when the Chip ID read returns all 1's. Signed-off-by: Olof Johansson <olof@lixom.net> Acked-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-10-13OMAP3: Clean up whitespace in mux configsOlof Johansson
Switch from space-based indentation to tab-based in mux configs, as pointed out by WD at: http://lists.denx.de/pipermail/u-boot/2009-September/061241.html Nothing but whitespace changes in this patch (diff -w gives no output). Signed-off-by: Olof Johansson <olof@lixom.net>
2009-09-05omap3: move the other boards to board/Jean-Christophe PLAGNIOL-VILLARD
