path: root/board/opalkelly/zynq
2017-11-29arm: zynq: Convert all board to use arch ps7_init codeMichal Simek
Use generic implementation. It will also reduce config data size for converted boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-29arm: zynq: Get rid of ps7_reset_apu() for syzygy boardMichal Simek
There is no reason to call separate function. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-29arm: zynq: Remove ps7_debug codeMichal Simek
SPL is not calling this code that's why it is dead code and can be removed. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-11-28arm: zynq: Add support for SYZYGY Hub boardTom McLeod
Add the Zynq-based SYZYGY Hub board from Opal Kelly. The board contains a Xilinx Zynq xc7z012s SoC, 1GB DDR3 RAM, and supports booting from SD. Signed-off-by: Tom McLeod <tom.mcleod@opalkelly.com> Cc: Michal Simek <monstr@monstr.eu> CC: Albert Aribaud <albert.u.boot@aribaud.net> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
