This board still doesn't select CONFIG_DM and seems to be umaintained.
As it makes progress on modernizing several DaVinci drivers more
difficult and the maintainer has not expressed interest in updating
it, this patch proposes to remove it.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
Push generic defines of gpio.h out of mach-davinci to drivers/gpio
now that non-davinci architectures are beginning to use this IP.
Signed-off-by: Keerthy <j-keerthy@ti.com>
[trini: Fix calimain build]
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
With d53ecad92f06 some unused interrupt related code was removed.
However all of these options are currently unused. Rather than migrate
some of these options to Kconfig we just remove the code in question.
The only related code changes here are that in some cases we use
CONFIG_STACKSIZE in non-IRQ related context. In these cases we rename
and move the value local to the code in question.
Fixes: d53ecad92f06 ("Merge branch 'master' of git://git.denx.de/u-boot-sunxi")
Signed-off-by: Christian Riesch <christian@riesch.at>
Cc: Manfred Rudigier <manfred.rudigier@omicronenergy.com>
Cc: Christoph Rüdisser <christoph.ruedisser@omicronenergy.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
Becuase the board select menu in arch/arm/Kconfig is too big,
move the Davinci board select menu to davinci/Kconfig.
Move also common settings (CONFIG_SYS_CPU="arm926ejs" and
CONFIG_SYS_SOC="davinci").
Reviewed-by: Tom Rini <trini@ti.com>
Cc: Sandeep Paulraj <s-paulraj@ti.com>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
The definitions inside emif_defs.h concern davinci nand driver and
should be in it's header. So create header file for davinci nand
driver and move definitions from emif_defs.h and nand_defs.h to it.
Acked-by: Vitaly Andrianov <vitalya@ti.com>
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
[trini: Fixup more davinci breakage]
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
[trini: Fixup common/cmd_io.c]
This patch moves all bootcount implementations into a common
directory: drivers/bootcount. The generic bootcount driver
is now usable not only by powerpc platforms, but others as well.
Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
Cc: Christian Riesch <christian.riesch@omicron.at>
Cc: Manfred Rudigier <manfred.rudigier@omicron.at>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de>
Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com>
Tested-by: Christian Riesch <christian.riesch@omicron.at>
Acked-by: Rob Herring <rob.herring@calxeda.com>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
This patch adds support for the Calimain board from
OMICRON electronics GmbH. The board features a Texas Instruments AM1808
SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and
CS3.
