This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
Patch by Hiroki Kaminaga, 11 Mar 2006
Use lowlevel_init() instead of platformsetup() [rename].
Patch by Peter Pearse, 06 Oct 2005
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
- update ARM boards to use constants from mach-types.h
* Patch by Curt Brune, 17 May 2004:
- Add support for Samsung S3C4510B CPU (ARM7tdmi based SoC)
- Add support for ESPD-Inc. EVB4510 Board
Add support for TI OMAP5912 OSK Board
* Patch by Sam Song May, 07 May 2004:
Fix typo of UPM table for rmu board
Add support for OMAP730 Perseus2 Development board
* Patch by Alan J. Luse, 29 Apr 2004:
Fix flash chip-select (OR0) option register setting on FADS boards.
Report MII network speed and duplex setting properly when
auto-negotiate is not enabled.
* Patch by Jarrett Redd, 29 Apr 2004:
Fix hang on reset on Ocotea board due to flash in wrong mode.
