path: root/board/omap5912osk
2006-05-10OMAP 5912/OSK: update EMIFS CS1 timings:Stefan Roese
Problems have been seen in the linux kernel's smc91x network driver due to improper bus timings. The latest 2.6 OMAP kernels currently have a workaround, but this fix belongs in u-boot. Patch by Kevin Hilman, 13 Oct 2005
2006-05-10Update omap5912osk board supportStefan Roese
- Fix OMAP support that omap5912osk compiles in current source tree - Update with code from "http://omap.spectrumdigital.com/osk5912" to fix problems with DDR initialization - Fix timer setup - Use CFI flash driver and support complete 32MB of onboard flash - Add "print_cpuinfo()" and "checkboard()" functions to display CPU (with frequency) and Board infos Patch by Stefan Roese, 10 May 2006
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-09-25Update omap5912osk board:Wolfgang Denk
Use drivers/cfi_flash.c instead of private flash driver; Remove hardcoded personalized settings from omap5912osk.h; Fix spacing with (RO) marks in 'flinfo' output. Patch by Michael Bendzick, 14 Jan 2005
2005-05-12* Fix debug code in omap5912osk flash driverLABEL_2005_05_13_0050wdenk
* Add support for MPC8247 based "IDS8247" board.
2004-10-10Patch by George G. Davis, 24 Aug 2004:wdenk
- update ARM boards to use constants from mach-types.h
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
