path: root/board/omap2420h4
2007-08-29Fix compilation error for omap2420h4_config.Dirk Behme
omap2420h4 switched to cfi, so remove old (already disabled) flash.c and flash_probe() calls in env_flash.c. Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-10-06CleanupWolfgang Denk
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-09-25CleanupWolfgang Denk
2005-09-25OMAP242x H4 board updateWolfgang Denk
- fix for ES2 differences. - switch to using the cfi_flash driver. - fix SRAM build address. - fix for GP device operation. - unlock SRAM for GP devices. - display more device information. - fix potential deadlock in omap24xx_i2c driver. - fix DLL load values to match dpllout*1 operation. - fix 2nd chip select init for combo DDR device. - add support for CFI Intel 28F256L18 on H4 board. Patch by Richard Woodruff, 03 Mar 2005
2005-09-25OMAP242x fix for GP device bootingWolfgang Denk
- Add SRAM unlock for GP devices. - Change DDR DLL unlock value to allow DPLLout*1 operation. Patches by Richard Woodruff, 21 Jan 2005:
2005-01-12* Patch by Robin Getz, 13 Oct 2004:wdenk
Add standalone application to change SMC91C111 MAC addresses, see examples/README.smc91111_eeprom * Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004: Fix Flash support for ARM Integrator CP.
2005-01-12* Some Cleanup.wdenk
* Patch by Richard Woodruff, 10 Jan 2005: Update support for OMAP2420 (ARM11) and H4 board: o clean up and add new types to H4 memory probe code. o fix to work with internal boot. o added PRCM config III operation. o fix marginal flash timings. o add revison ATAG usage. o enable voltage scaling at power chip. o fix compile error for i2c. * Fix network problem (error when receiving multiple ARP packets)
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patches by Richard Woodruff, 01 Oct 2004:wdenk
add support for the TI OMAP2420 processor and its H4 reference board * Patch by Christian Pellegrin, 24 Sep 2004: Added support for NE2000 compatible (DP8390, DP83902) NICs.
