path: root/board/o2dnt
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-08-11O2DNT: added hardware flash protect support, macros cleanup.
2005-08-09O2DNT platform specific code.
