path: root/board/nx823
2013-04-02replace last __bss_end__ occurrences with __bss_endAlbert ARIBAUD
Simon Glass' commit 3929fb0a141530551b3fce15ee08629f80d5ef2a, which changed all occurrences of __bss__end__ into __bss_end, left behind some untouched __bss_end__ occurrences in all 33 u-boot.lds.debug files, in board/mousse/u-boot.lds.ram and in board/mousse/u-boot.lds.rom. These are replaced here. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-03-27ppc: cleanup compiler errors/warningsHeiko Schocher
Current u-boot top of tree builds with warnings/errors for the following boards: ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823 RPXClassic debris PN62 following patch solves this. Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2002-08-26Initial revisionwdenk
2002-03-08Initial revisionwdenk
2001-08-05Initial revisionwdenk
