path: root/board/nvidia/seaboard/Makefile
2012-09-07ARM: tegra: remove redundant mkdirs from board MakefilesStephen Warren
None of harmony, seaboard, ventana, whistler directly build files from ../common/, so there's no need to mkdir the obj directory for such files. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Implement SPI / UART GPIO switchSimon Glass
The Tegra2 Seaboard has the unfortunate feature that SPI and the console UART are multiplexed on the same pins. We need to switch between one and the other during SPI and console activity. This new file implements a switch and keeps track of which peripheral owns the pins. It also flips over the controlling GPIO as needed Since we are adding a second file to board/nvidia/common, we create a proper Makefile there and remove the direct board.o include from board/nvidia/seaboard/Makefile Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-07arm: tegra2: fix out-of-tree buildChe-liang Chiou
The out-of-tree build fails because the Makefiles in question depend on source files of another directory but do not explicitly mkdir that directory. As a matter of fact, other Makefiles under board/*/ directory that refer to source files under another directory explicitly call mkdir. This patch adds explicit mkdir's to the Makefiles in question, and verifies that out-of-tree build is working. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-04-27arm: Tegra2: Move clk/mux init to board_early_init_f, add GPIO initTom Warren
2011-02-21arm: Tegra2: Add support for NVIDIA Seaboard boardTom Warren
