path: root/board/nvidia/p2571
2016-07-21ARM: tegra: p2371-2180: A03 board PMIC config updateStephen Warren
Rev A03 of P2180 requires some PMIC programming adjustments, yet the PMIC's own OTP has not been updated. Consequently, U-Boot must make these changes itself. NVIDIA's syseng team has confirmed that these changes can be enabled on all board revisions without issue. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-05-31ARM: tegra: use DT bindings for GPIO namingStephen Warren
There are currently many places that define the list of all Tegra GPIOs; the DT binding header and custom Tegra-specific header file gpio.h. Fix the redundancy by replacing everything with the DT binding header file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-11-12ARM: tegra: simplify GPU setupAlexandre Courbot
Enable the GPU node in the system-wide ft_system_setup() hook instead of the board-specific ft_board_hook(). This allows us to enable GPU per SoC generation instead of per-board as we did initially. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: enable GPU DT node when appropriateAlexandre Courbot
T124/210 requires some specific configuration (VPR setup) to be performed by the bootloader before the GPU can be used. For this reason, the GPU node in the device tree is disabled by default. This patch enables the node if U-boot has performed VPR configuration. Boards enabled by this patch are T124's Jetson TK1 and Venice2 and T210's P2571. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: add comment re: autogeneration to pinmux headersStephen Warren
Add a comment block to the top of each generated Tegra pinmux header file indicating that the file was auto-generated, should not be manually edited, and with a pointer to the tool and command used to generate it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05T210: P2571: Turn CPU fan onTom Warren
CPU board (E2530) has a fan - turn it on via GPIO to keep the SoC cool. Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05T210: P2571: Enable SD-card power via PMIC LDO2Tom Warren
This was done in the 32-bit AVP loader (SPL) but is board-specific so should be moved to the CPU portion. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2015-07-28T210: Add support for 64-bit T210-based P2571 boardTom Warren
Based on Venice2, incorporates Stephen Warren's latest P2571 pinmux table. With Thierry Reding's 64-bit build fixes, this will build and and boot in 64-bit on my P2571 (when used with a 32-bit AVP loader). Signed-off-by: Tom Warren <twarren@nvidia.com>
