path: root/board/nvidia/p2371-2180/pinmux-config-p2371-2180.h
2016-05-31ARM: tegra: use DT bindings for GPIO namingStephen Warren
There are currently many places that define the list of all Tegra GPIOs; the DT binding header and custom Tegra-specific header file gpio.h. Fix the redundancy by replacing everything with the DT binding header file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-10-02ARM: tegra: p2371-2180: import latest pinmuxStephen Warren
In order to avoid any assumptions about any device connected to P2371-2180's expansion connector, the latest pinmux spreadsheet configures all muxable pins on that connector to be GPIO inputs, with on-chip pulls where appropriate. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-09-16ARM: tegra: Add p2371-2180 boardStephen Warren
P2371-2180 is a P2180 CPU board married to a P2597 I/O board. The combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, Ethernet via USB3, USB3 host port, SATA, PCIe, and two GPIO expansion headers. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
