path: root/board/nvidia/p2371-0000
2016-05-31ARM: tegra: use DT bindings for GPIO namingStephen Warren
There are currently many places that define the list of all Tegra GPIOs; the DT binding header and custom Tegra-specific header file gpio.h. Fix the redundancy by replacing everything with the DT binding header file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: Add p2371-0000 boardStephen Warren
P2371-0000 is a P2581 or P2530 CPU board married to a P2595 I/O board. The combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, Ethernet via USB3, USB3 host port, SATA, a GPIO expansion header, and an analog audio jack. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
