path: root/board/nvidia/harmony
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-07-11ARM: tegra: enable LCD panel on HarmonyStephen Warren
Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2013-03-14Tegra: MMC: Add DT support to MMC driver for all T20 boardsTom Warren
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional. Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-11-19ARM: tegra: enable 8-bit SD slots in board filesStephen Warren
Harmony contains an SD slot with all 8 bits routed. This allows plugging in an eMMC-chip-in-SD-form-factor. Seaboard/Springbank/Ventana/AC100 all have an eMMC chip with all 8 bits hooked up. Now that the U-Boot eMMC code fully supports 8-bit operation, initialize those ports as 8-bit instead of 4-bit to improve performance. Whistler was already registering its ports as 8-bit. TrimSlice doesn't have any 8-bit ports. I don't have any Avionic Design boards nor the Colibri board to test with. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: Harmony: enable ULPI USB portStephen Warren
The ULPI port is routed onto pins on the mini PCI Express connector. A standard breakout board may be used to access the port. * Add required DT entries to configure the ULPI port. * Setup up the ULPI pinmux in the board code. * Enable multiple USB controller and ULPI support in the board config. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15tegra20: rework UART GPIO handlingLucas Stach
Rename board provided gpio_config_uart() to gpio_early_init_uart() as it does the same thing as the equally called function provided by the uart-switch code. This allows to simply call this function in early board init whether or not we are building with CONFIG_UART_SWITCH defined. Also provide a weak symbol for this function, to avoid the need to provide this function for boards that don't need any fixup. This patch supersedes the earlier posted "tegra: convert gpio_config_uart to weak symbol". Build tested with MAKEALL -s tegra20 Signed-off-by: Lucas Stach <dev@lynxeye.de> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15Tegra20: Move some include files to arch-tegra for sharing with Tegra30Tom Warren
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h. Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20' 'root' file. All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07ARM: tegra: remove redundant mkdirs from board MakefilesStephen Warren
None of harmony, seaboard, ventana, whistler directly build files from ../common/, so there's no need to mkdir the obj directory for such files. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07mmc: tegra2: rename tegra2_mmc.* to tegra_mmc.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-02-12tegra: Use funcmux for MMC on harmonySimon Glass
Use the new funcmux_select() feature to set up the MMC pin mux. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/masterTom Warren
Seaboard changes have removed the need for common/board.o in the Makefile. Propagate this change to the other Tegra2 builds. Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Move tegra2_mmc_init() prototype to public header.Thierry Reding
tegra2_mmc_init() is implemented by the Tegra2 MMC driver. Since most of the Tegra2-based boards will need to call it, this commit exports it in the new public asm/arch/mmc.h header file to prevent each board from providing its own prototype. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Modify MMC driver to handle power and cd GPIOsStephen Warren
Pass the GPIO numbers for power and card detect to tegra2_mmc_init(), and modify that function to perform all required GPIO initialization. This removes the need for board files to perform these operations. Move board_mmc_getcd() into tegra2_mmc.c now that the driver knows which GPIOs to use. Update affected call-sites in seaboard.c and harmony.c. Note that this change should make all SD ports work on Harmony, since the required GPIO setup is now being performed. v4: Fix prototype of tegra2_mmc_init() in board.h to match driver change. Remove prototype of gpio_config_mmc() from board.h Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: Andy Fleming <afleming@gmail.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Move board_mmc_init into board filesStephen Warren
For Seaboard, this is mostly a cut/paste of board_mmc_init() and pin_mux_mmc() into seaboard.c; pin_mux_mmc() was modified to add some missing pinmux_tristate_disable calls for the GPIOs. For Harmony, those functions were modified to configure SDMMC2 (index 2) instead of SDMMC3 (index 1), since that's what is present on the board. However, harmony.c is still missing the required GPIO setup, so neither port is likely to function correctly yet. This will be fixed in the next change. v4: Include board.h to prototype tegra2_mmc_init(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-10-27tegra2: Enable MMC for SeaboardTom Warren
This adds the required GPIO and pinmux configuration to make eMMC / SD work on Seaboard. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Tom Warren <twarren@nvidia.com>
2011-10-22build: add missing $(AR)->$(cmd_link_o_target) updateMike Frysinger
Seems people fixed their files to use libfoo.o, but didn't actually update the creation targets to use $(cmd_link_o_target). Update the rest of the Makefile's found with grep. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Simon Glass <sjg@chromium.org>
2011-09-07arm: tegra2: fix out-of-tree buildChe-liang Chiou
The out-of-tree build fails because the Makefiles in question depend on source files of another directory but do not explicitly mkdir that directory. As a matter of fact, other Makefiles under board/*/ directory that refer to source files under another directory explicitly call mkdir. This patch adds explicit mkdir's to the Makefiles in question, and verifies that out-of-tree build is working. Signed-off-by: Che-Liang Chiou <clchiou@chromium.org> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-04-27arm: Tegra2: Move clk/mux init to board_early_init_f, add GPIO initTom Warren
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
