path: root/board/nvidia/e2220-1170
2016-05-31ARM: tegra: use DT bindings for GPIO namingStephen Warren
There are currently many places that define the list of all Tegra GPIOs; the DT binding header and custom Tegra-specific header file gpio.h. Fix the redundancy by replacing everything with the DT binding header file. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: Add e2220-1170 boardStephen Warren
E2220-1170 is a Tegra210 bringup board with onboard SoC, DRAM, eMMC, SD card slot, HDMI, USB micro-B port, and sockets for various expansion modules. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
