This CL simplifies how cros gpios are handled by moving the required logic out
of cros_gpio.c and into the application logic. This means that cros_gpio.c
assumes that none of the gpios are required, and just returns an error when
fetch is called. It's up to the caller of fetch to determine whether or not they
should ignore the error or act upon it.
BUG=chromium-os:21700
TEST=Tested on asymptote, ensured gpio access worked as expected.
Change-Id: Ief3f1915026bfe981d345b9cc4709fef19edc7bf
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Reviewed-on: http://gerrit.chromium.org/gerrit/10174
Add default values for the power and lid switches such that a dts file can
exclude them and not suffer from immediate shutoffs and spam on boot.
Also remove the lid switch from seaboard dts file since it is not relevant on
that platform.
BUG=chrome-os-partner:6027,chromium-os:17062
TEST=Tested on asymptote and seaboard
Change-Id: I0bec112af345f7bef4cfbdc7cb44c0017cfecad3
Reviewed-on: http://gerrit.chromium.org/gerrit/10037
Change tegra2 to tegra to make it more generic.
BUG=chromium-os:19004
TEST=build and boot on Seaboard
Change-Id: Iad6de3bb6cc6031167862054b78a57f66dea9cd5
Reviewed-on: http://gerrit.chromium.org/gerrit/7127
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
We want to move to the idea of drivers and boards using generic tegra
include files, and have these include files deal with the tegra2/3
differences. This will make it easier to share code between tegra2/3.
Change-Id: I9c4eec30707e41678fb307982a34fe383694ba16
Reviewed-on: http://gerrit.chromium.org/gerrit/7000
Reviewed-by: Yen Lin <yelin@nvidia.com>
Reviewed-by: Tom Warren <twarren@nvidia.com>
cros_gpio module used a ad-hoc format of GPIO config, and it should
use <&gpio ...> instead. This patch changes the format of GPIO config.
Note: In between calls to gpio_direction_input() (in fdt_setup_gpio())
and calls to gpio_get_value(), you have to insert a small delay if the
input source is connected to the GPIO through a sufficiently large
series resister (say, 200K ohm) so that the RC time constant for
charging the gate capacitance on the input is non-trivial.
As a matter of fact, I tested on Kaen and Aebl, and found only write
protect GPIO needs this delay, and the delay time is less than 10 us.
And we may safely hide this delay by decoupling the initialization and
reading of GPIOs.
BUG=none
TEST=Run "vboot_test gpio" on Kaen and Aebl, and check GPIO readings
TEST=Run "crossystem" on Kaen and Aebl after boot, and check GPIO readings
Change-Id: Ib4d93c2ce156eb09ffc24a3882f83490d25c1e91
Reviewed-on: http://gerrit.chromium.org/gerrit/5726
Tested-by: Che-Liang Chiou <clchiou@chromium.org>
This reverts commit 23cefdce356de66442d858abf12c72afc8d33cac.
Since we changed our minds about loading FMAP information from CBFS, we can go
back to using the same mechanism on ARM and x86.
BUG=chrome-os-partner:5432
TEST=Built and booted on x86-alex and verified that the FMAP information showed
up in debugging output from vboot_twostop.
Change-Id: Id41c82ca24dbfa301559e24104b5e226ec9b7e03
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: http://gerrit.chromium.org/gerrit/5864
Reviewed-by: Stefan Reinauer <reinauer@google.com>
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
Tested-by: Gabe Black <gabeblack@chromium.org>
This change makes the FMAP configuration decoding function board specific so
that it can, for instance, use CBFS to store the FMAP on x86. The ARM
implementation uses fdt_decode_twostop_fmap in its implementation and should
behave the same. The new more generic interace is called decode_twostop_fmap.
BUG=chrome-os-partner:5248
TEST=Built, installed and booted on Kaen, built and installed on Alex, ran
vboot_twostop and saw new "unimplemented" message.
Change-Id: I07f6f8f7c8a62c5998ec4919d4609a7ac84783da
Reviewed-on: http://gerrit.chromium.org/gerrit/5233
This change removes the device tree from one of the vboot support APIs so
that they fit better with coreboot u-boot. Specifically this is
cros_gpio_fetch which is for getting GPIO values. Coreboot will read these and
provide the values through its coreboot tables. The device tree pointer is
global data so it doesn't need to be passed around as a parameter to be
accessible.
This change also removes the device tree from other interfaces in
cmd_vboot_twostop.c so the structure of the code is more consistent. This way
people can expect the device tree to always be the one pointed at by the
global data and not sometimes one and sometimes the other, even though as
written those will be equivalent. This change also takes the opportunity to
mark the local functions in that file static, which is most of them.
BUG=chrome-os-partner:4552
TEST=Built for x86-alex and tegra2_kaen. Installed and booted to chromeos
login on Kaen.
Change-Id: I084e774d97025d9ec71abe09c92fab8a7827892f
Reviewed-on: http://gerrit.chromium.org/gerrit/5232
Reviewed-by: Gabe Black <gabeblack@chromium.org>
This patch is derived from kernel's seaboard power management driver and
tps6586x regulator driver.
BUG=chrome-os-partner:4738
TEST=press power button or close lid in dev and rec mode
Change-Id: I285856b52dcaba6ba3c29cacf47a8c592fbe3256
Reviewed-on: http://gerrit.chromium.org/gerrit/4922
The warning is unused variable.
BUG=none
TEST=build without error:
USE="-cros-debug" emerge-tegra2_aebl chromeos-u-boot
Change-Id: I7315ca9d802826bee132525668d7e1f686ed4786
Reviewed-on: http://gerrit.chromium.org/gerrit/4723
Tested-by: Tom Wai-Hong Tam <waihong@chromium.org>
The predicate function is_cold_boot() is in fact telling you whether we
are booting from a processor reset.
BUG=chrome-os-partner:5100
TEST=build cleanly
Change-Id: I70f56448dd1b327426cf759854c35e20e0b4cfcf
Reviewed-on: http://gerrit.chromium.org/gerrit/4644
As ARM accesses non-volatile storage from eMMC and x86 from CMOS, the
accessor functions that export to vboot_reference are really not
board-independent and so should be put at a board-dependent module.
BUG=none
TEST=make
Change-Id: Idbd4d70372770597aa8897524ee6a1ffe173bfea
Reviewed-on: http://gerrit.chromium.org/gerrit/4646
Reviewed-by: Tom Wai-Hong Tam <waihong@chromium.org>
TEST=build without error, run "vboot_test gpio" on Aebl
Tegra2 # vboot_test gpio
cros_gpio: wpsw : port= 59, polarity=0, value=1
cros_gpio: recsw : port= 56, polarity=0, value=0
cros_gpio: devsw : port=168, polarity=1, value=0
cros_gpio: lidsw : port= 23, polarity=0, value=1
cros_gpio: pwrsw : port=170, polarity=0, value=0
--- Pressed the power key ---
cros_gpio: pwrsw : port=170, polarity=0, value=1
--- Closed the lid ---
cros_gpio: lidsw : port= 23, polarity=0, value=0
Change-Id: Ib9fe188f39e266f806a823e694d8ea0867a8ef19
Reviewed-on: http://gerrit.chromium.org/gerrit/4485
vboot_reference is redesigned and deprecates parts of its API. This
patch remove those U-Boot integration codes that are based on the
deprecated API.
BUG=none
TEST=clean build okay
Change-Id: I45e08b8f5b6cec8f1bd62e760361f169aac4b687
Reviewed-on: http://gerrit.chromium.org/gerrit/4382
BUG=chromium-os:17424
TEST=boot on Seaboard
Change-Id: I103c7060ed37c340e173498cfa70cf3493b2c503
Reviewed-on: http://gerrit.chromium.org/gerrit/4000
Change-Id: I9b1f42801eedfba5e7f4e85a5b3ac1e1c106b6bf
Reviewed-on: http://gerrit.chromium.org/gerrit/3998
The variants of Chrome OS verified boot are:
* chromeos_seaboard_onestop implements twostop firmware based on
prior-redesigned vboot_reference. It is called onestop because it was
implementing onestop boot.
* chromeos_seaboard_vboot implements ordinary verified boot, which has
bootstub, recovery, normal, and developer firmware, based on
* chromeos_tegra2_twostop implements twostop firmware based on
redesigned vboot_reference. This variant is going to replace
chromeos_seaboard_onestop.
We split config flags into:
* CONFIG_CHROMEOS enables codes that are shared among all variants.
* CONFIG_CHROMEOS_VBEXPORT enables codes that implements APIs defined in
vboot_api.h.
* CONFIG_CHROMEOS_{ONESTOP,TWOSTOP,VBOOT} enables codes that are
specific to each variant.
Note that we would further cleanup or reorganize config flags after we
migrate from chromeos_seaboard_onestop to chromeos_tegra2_twostop.
TEST=build cleanly
Change-Id: I7574ec9376047693065b4295edb85b65acb4ea37
Reviewed-on: http://gerrit.chromium.org/gerrit/3943
Reviewed-by: Rong Chang <rongchang@chromium.org>
BUG=none
TEST=boot and see gpio port number are set properly
Change-Id: Ib4dbd54d7a50b6e31fb90c2c1977babab5f7b78b
Reviewed-on: http://gerrit.chromium.org/gerrit/3670
The raw gpio readings are not the logical values of true/false. A gpio
may connect to device that is either high active or low active. That is,
a raw reading of 1 from low active device actually means "false". In
this context, we refer to this as a gpio's polarity. Note that a gpio
polarity may differ board by board, depending on the actual wiring of
the board.
The u-boot and the crossystem (a user space program) needs the
polarities to correctly interpret the raw gpio readings. The crossystem
needs polarities for the gpio values in the crossystem data blob that
u-boot passes to kernel (these values are "post-interpretation").
Instead, the crossystem is required to read "current" raw gpio readings
and interpret these readings to a user.
Note: I merely copied polarity configuration to kaen and aebl, but I did
not test its correctness.
BUG=chromium-os:16508
1. Turn on Seaboard with dev switch on and rec switch off
2. Check debug output of u-boot
cros_onestop_firmware: polarity:
cros_onestop_firmware: - wpsw: 1
cros_onestop_firmware: - recsw: 0
cros_onestop_firmware: - devsw: 1
cros_onestop_firmware: gpio value:
2. Check /proc/device-tree/crossystem/
$ od -x polarity_write_protect_sw
0000000 0000 0100
0000004
$ od -x polarity_recovery_sw
0000000 0000 0000
0000004
$ od -x polarity_developer_sw
0000000 0000 0100
0000004
Change-Id: Ie92c31ce0abddf0271e73669b429621deaed76dd
Reviewed-on: http://gerrit.chromium.org/gerrit/3650
We modify onestop firmware to support twostop booting. Basically we only
implemented R/W firmware verification.
TODO
* Read R/W firmware from mmc
* Set main R/W firmware A or B in crossystem data
* Read TPM's firmware version
BUG=chromium-os:17056
TEST=boot r/w firmware on seaboard
Change-Id: I77657547a2eafd1f7a4dafade26911cf1cc069b0
Reviewed-on: http://gerrit.chromium.org/gerrit/3603
tegra gpio dirver
This is the sixth of the seven commits in the series. For more
information, please refer to the first commit.
Changes in this commit:
* rewrite gpio accessor to the new tegra gpio dirver
TEST=manual; see the first commit
Change-Id: Ib478e2b4f9f35b86acb067e7c35fde725e57f056
Reviewed-on: http://gerrit.chromium.org/gerrit/2680
The compiler warnings and errors due to cherry-picking verified boot
integration library into new u-boot codebase are fixed here.
This and the following six commits only give you a compilable
repository, and do not give you a working verified boot; neither onestop
nor the old four-variants style of verified boot are supposed to be
functioning.
* delete obsolete files:
- cpu_state.c
- eeprom_driver.c
* delete unused firmware storage device:
- firmware_storage_{nand,ram}.c
TEST=manual
After all seven commits are checked in, you should be able to run:
make ARCH=arm \
CROSS_COMPILE=armv7a-cros-linux-gnueabi- \
USE_PRIVATE_LIBGCC=yes \
VBOOT=/build/tegra2_seaboard/usr \
chromeos_seaboard_onestop_config
make ARCH=arm \
all
Change-Id: I8a73e5536277a7c22dad3f95c1a33da90689a6f3
Reviewed-on: http://gerrit.chromium.org/gerrit/2676
U-Boot debug output is very verbose, and sometimes does not help
debugging verified boot related changes. This commit let us enable
vboot-related debug output separately.
BUG=chromium-os:15747
TEST=boot and see vboot-related debug output
Cherry-pick: 84c65f7
Change-Id: I934d46654777347f09d9d3d71c55b3e478fd02c6
Reviewed-on: http://gerrit.chromium.org/gerrit/1532
BUG=none
TEST=[ $(crossystem wpsw_boot) = 1 ] && [ crossystem hwid = "$HWID_YOU_ASSIGNED" ]
Cherry-pick: 5f30788
Change-Id: Id29b56748fafc6ad64cd336207ac7ef43befbbf5
Reviewed-on: http://gerrit.chromium.org/gerrit/1004
The verified boot spec requires that firmware cold (not warm) reboots so
that TPM gets reseted.
BUG=chrome-os-partner:3574
TEST=manual
1. Run load_fw twice, and verify that SetupTPM failed in the second run
CrOS> cros load_fw 0x0 0x01000000 0x00400000 0x10000000
DEBUG: TPM: SetupTPM(r0, d0)
DEBUG: TPM: SetupTPM() succeeded
DEBUG: Unable to setup TPM and read stored versions.
2. Run load_fw twice and a reset in between, and results the same
CrOS> reset
3. Run load_fw twice and a "cros cold_reboot" in between, and verify
that SetupTPM succeeds in both runs
CrOS> cros cold_reboot
Cherry-pick: bbb6ba7
Change-Id: Ie74bb214c80714d1814b4ae295c4780aa2bc7ddc
Reviewed-on: http://gerrit.chromium.org/gerrit/756
The removed TPM functions are implemented in verified boot reference
library (vboot_reference), and so this commit removes the implementation
of these functions in u-boot.
This commit also removes codes that are related to x86-specific CPU
state (S3 resume).
BUG=none
TEST=CROSS_COMPILE=armv7a-cros-linux-gnueabi- ./MAKEALL chromeos
Cherry-pick: 75707bc
Change-Id: Id4a967b9dd16549bb26adbe27ce96caa713bfe30
Reviewed-on: http://gerrit.chromium.org/gerrit/515
Note: The implementation of SPI interface is empty here and is
sent out in cl/6696066 to reduce the size of this CL.
The following test results are conducted with cl/6696066.
1. Verify that bootstub can boot to rewritable firmware
2. Verify that refactoring does not break load_fw
(Read firmware image from SPI flash)
CrOS> sf probe 0
SF: Detected W25Q16B with page size 256, total 2 MiB
2048 KiB W25Q16B at 0:0 is now current device
CrOS> sf read 0x01000000 0 0x00400000
(Test load_fw)
CrOS> cros load_fw 0 0x01000000 0x00400000 0x10000000
LoadFirmware returns: LOAD_FIRMWARE_SUCCESS: firmware_index: 0
3. Verify that refactoring does not break load_k
(Following from previous command)
(Insert Chrome OS image into SDCard slot)
CrOS> mmc init 1
EMMC 1 Probed Successfully
mmc1 is available
CrOS> cros bootdev set mmc 1
Set boot device to mmc 1 0
(Test load_k)
CrOS> cros load_k 0 0x10000000
boot_flags: 0x00000004
shared_data_blob: 0x10000000
kernel_buffer: 0x027012f0
success: good kernel found on device
kernel_buffer: 0x0040c000
partition_number: 2
bootloader_address: 0x736000
bootloader_size: 0x1000
partition_guid: fa e2 d2 39 82 ab 4b ff 93 b7 25 5e 88 a4 18 54
bytes_per_lba: 512
ending_lba: 0x003ce022
Change-Id: I12d24f8df2535a1cd58e120552431b9314224f6e
R=robotboy@chromium.org,waihong@chromium.org
BUG=none
TEST=see above
Review URL: http://codereview.chromium.org/6676109
The bootstub should output like the following:
U-Boot 2010.09-00059-ga8a8981 (Mar 16 2011 - 14:00:35)
Board: Tegra2 chromeos/tegra2/seaboard/stub
DRAM: 1 GiB
Using default environment
In: tegra-kbc
Out: lcd
Err: lcd
Hit any key to stop autoboot: 0
DEBUG: LoadFirmware started...
DEBUG: Checking key block signature...
DEBUG: Firmware 0 is valid.
DEBUG: Will boot firmware index 0
The cros load_fw command should output like the following:
(assume you load firmware image at [0x01000000:0x011d0000]
CrOS> cros load_fw 0 0x01000000 0x001d0000 0x10000000
Type following command in developer firmware:
(Assume that you inserted a Chrome OS SD card image)
CrOS> mmc init 1
mmc1 is available
CrOS> cros load_k 4 0x10000000
partition_number: 2
bytes_per_lba: 512
R=waihong@chromium.org
BUG=None
TEST=MAKEALL successfully and run commands above
Review URL: http://codereview.chromium.org/6688063
Change-Id: Ia4f44a9de1703c7cef0f6b52d8bc951ff1cb81ee
Renaming the caller_internal_t for better reflecting its purpose.
BUG=chromium-os:1302
Review URL: http://codereview.chromium.org/6594066
Change-Id: I0e28c5934fdbd198ab4fdb278a33d4707767b3c6
BUG=None
TEST=None
Review URL: http://codereview.chromium.org/6602003
Change-Id: I6dd474c1d111499db8940a8aea43045b6e4e00a6
BUG=chromium-os:10496
TEST=build successfully and run "cros test_gpio" in u-boot
Review URL: http://codereview.chromium.org/6546014
Change-Id: I30ad04bef6a6fc4ac0dc9ff2c17a1087b18d9909
BUG=none
TEST=emerge-tegra2_seaboard chromeos-u-boot-next
Review URL: http://codereview.chromium.org/6543034
Change-Id: I88dfd38aedd81281415ecb8156181a6cc4d46495
