path: root/board/nokia
2013-05-10twl4030: make twl4030_i2c_read_u8 prototype consistentNishanth Menon
u-boot standard i2c read prototype is i2c_read(addr, reg, 1, &buf, 1) twl4030_i2c_read_u8(u8 addr, u8 *val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_read_u8(u8 addr, u8 reg, u8 *val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-05-10twl4030: make twl4030_i2c_write_u8 prototype consistentNishanth Menon
u-boot standard i2c register write prototype is i2c_reg_write(u8 addr, u8 reg, u8 val) twl4030_i2c_write_u8(u8 addr, u8 val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_write_u8(u8 addr, u8 reg, u8 val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
