path: root/board/nokia
2015-01-12Nokia RX-51: Do not call secure PPA routine on non secure devicesPali Rohár
Since commit 41623c91b09a0c865fab41acdaff30f060f29ad6 u-boot running in qemu is crashing in function do_omap3_emu_romcode_call(). RX-51 board uses this function for Cortex-A8 errata 430973 workaround (Set IBE bit in ACR) which is needed only on real secure device and not in qemu. This board patch just disable calling secure PPA routine on non secure devices. Qemu implements GP device and with this patch u-boot is working in qemu again. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Acked-by: Pavel Machek <pavel@ucw.cz>
2014-12-04omap_hsmmc: Board-specific TWL4030 MMC power initializationsPaul Kocialkowski
Boards using the TWL4030 regulator may not all use the LDOs the same way (e.g. MMC2 power can be controlled by another LDO than VMMC2). This delegates TWL4030 MMC power initializations to board-specific functions, that may still call twl4030_power_mmc_init for the default behavior. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com> [trini: Fix omap3_evm warning, add twl4030.h] Signed-off-by: Tom Rini <trini@ti.com>
2014-08-30omap3: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the OMAP3 board select menu to omap3/Kconfig. Move also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="omap3 Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Tom Rini <trini@ti.com>
2014-07-23stdio: Pass device pointer to stdio methodsSimon Glass
At present stdio device functions do not get any clue as to which stdio device is being acted on. Some implementations go to great lengths to work around this, such as defining a whole separate set of functions for each possible device. For driver model we need to associate a stdio_dev with a device. It doesn't seem possible to continue with this work-around approach. Instead, add a stdio_dev pointer to each of the stdio member functions. Note: The serial drivers have the same problem, but it is not strictly necessary to fix that to get driver model running. Also, if we convert serial over to driver model the problem will go away. Code size increases by 244 bytes for Thumb2 and 428 for PowerPC. 22: stdio: Pass device pointer to stdio methods arm: (for 2/2 boards) all +244.0 bss -4.0 text +248.0 powerpc: (for 1/1 boards) all +428.0 text +428.0 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Reviewed-by: Marek Vasut <marex@denx.de>
2014-02-19Move #ifdef(CONFIG_DISPLAY_CPUINFO) from caller to calleeMasahiro Yamada
- When CONFIG_DISPLAY_CPUINFO is not enabled, print_cpuinfo() should be defined as an empty function in a header, include/common.h - Remove #ifdef CONFIG_DISPLAY_CPUINFO .. #endif from caller, common/board_f.c and arch/arm/lib/board.c - Remove redundant prototypes in arch/arm/lib/board.c, arch/arm/include/asm/arch-am33x/sys_proto.h and board/nokia/rx51/rx51.h, keeping the one in include/common.h - Add #ifdef CONFIG_DISPLAY_CPUINFO to the func definition where it is missing Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-05-10twl4030: make twl4030_i2c_read_u8 prototype consistentNishanth Menon
u-boot standard i2c read prototype is i2c_read(addr, reg, 1, &buf, 1) twl4030_i2c_read_u8(u8 addr, u8 *val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_read_u8(u8 addr, u8 reg, u8 *val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-05-10twl4030: make twl4030_i2c_write_u8 prototype consistentNishanth Menon
u-boot standard i2c register write prototype is i2c_reg_write(u8 addr, u8 reg, u8 val) twl4030_i2c_write_u8(u8 addr, u8 val, u8 reg) does not provide consistency, so switch the prototype to be consistent with rest of u-boot i2c operations: twl4030_i2c_write_u8(u8 addr, u8 reg, u8 val) Signed-off-by: Nishanth Menon <nm@ti.com>
2013-03-08omap_hsmmc: add driver check for write protectionNikita Kiryanov
Add check for write protection in omap mmc driver. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Tom Rini <trini@ti.com>
2013-03-08omap_hsmmc: implement driver check for card detectionNikita Kiryanov
Implement driver check for card detection. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
2012-10-30New board support: Nokia RX-51 aka N900Pali Rohár
Based on previous work by: Alistair Buxton <a.j.buxton@gmail.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Cc: Ивайло Димитров <freemangordon@abv.bg>
