2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-26 | * Patches by Robert Schwebel, 26 Jun 2003:U-Boot-0_4_0 | wdenk | |
- logdl - csb226 - innokom * Patch by Pantelis Antoniou, 25 Jun 2003: update NetVia with V2 board support | |||
2003-06-25 | * Header file cleanup for ARMLABEL_2003_06_26_2220 | wdenk | |
* Patch by Murray Jensen, 24 Jun 2003: - make sure to use only U-boot provided header files - fix problems with ".rodata.str1.4" section as used by GCC-3.x | |||
2002-11-03 | Initial revision | wdenk | |
