path: root/board/netta
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-10Major PCMCIA Cleanup to make code better readable and maintainable.Wolfgang Denk
Notes: - Board-dependend code for RPXLITE and RPXCLASSIC-based boards placed to the drivers/rpx_pmcia.c file to avoid duplication. Same for TQM8xx-based boards (drivers/tqm8xx_pmcia.c). - drivers/i82365.c has been split into two parts located at board/atc/ti113x.c and board/cpc45/pd67290.c (ATC and CPC45 are the only boards using CONFIG_82365). - Changes were tested for clean build and *very* *few* boards.
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-06-08* Patch by Rishi Bhattacharya, 08 May 2004:wdenk
Add support for TI OMAP5912 OSK Board * Patch by Sam Song May, 07 May 2004: Fix typo of UPM table for rmu board
2004-06-07Patch by Pantelis Antoniou, 5 May 2004:wdenk
- Intracom board update. - Add Codec POST.
2004-04-15* Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
- add auto-complete support to the U-Boot CLI - add support for NETTA and NETPHONE boards; fix NETVIA board * Patch by Yuli Barcohen, 28 Mar 2004: - Add support for MPC8272 family including MPC8247/8248/8271/8272 - Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS) - Change configuration method for MPC8260ADS family
