path: root/board/netstar
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-07NetStar: eeprom - fix linker errorLadislav Michl
linking eeprom with libgeneric.a is not really needed and causes following error: ../../lib_generic/libgeneric.a(string.o): In function `strcmp': lib_generic/string.c:152: multiple definition of `strcmp' ../../examples/standalone/libstubs.a(stubs.o):include/_exports.h:24: first defined here Remove eeprom linker script as well and generate entry point object (to start application by jumping on its beginning) on the fly. Out-of-tree build tested as well. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07NetStar: eeprom - be less verboseLadislav Michl
Use shorter yet descriptive messages, replace printf() with puts() where appropriate. This saves few bytes. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-03-07NetStar: eeprom - undefined reference to `memset'Ladislav Michl
Defining partially initialized struct eth_device on stack means gcc has to zero out it, and some gcc versions optimize this with an implicit call to memset. Move definition to data section to avoid that (it has also nice side effect that we need not to pass it to helper functions anymore) Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12NetStar: Remove debug junk leaked into eeprom utilityLadislav Michl
This patch removes debug junk leaked into eeprom utility. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-02-12NetStar: make crcit utility more readableLadislav Michl
This patch makes the crcit utility more readable Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-07-23unify HOST_CFLAGS and HOSTCFLAGSMike Frysinger
The top build system sets up HOSTCFLAGS a bit and exports it, but other places use HOST_CFLAGS instead. Unify the two as HOSTCFLAGS so that the values stay in sync. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-22Fix "ld: cannot find -lstubs" build errorWolfgang Denk
Commit 1bc15386 moved the examples/ to examples/standalone but failed to adapt the Makefiles that need to link against libstubs.a Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-04netstar: fix crc32.c dependancy locationJean-Christophe PLAGNIOL-VILLARD
2009-03-31NetStar: fix NANDLadislav Michl
Fix NAND support broken during new NAND code merge. Move those few lines of code to board/netstar/netstar.c Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-29NetStar: add RTC supportLadislav Michl
Add RTC support. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-29NetStar: use generic flash driverLadislav Michl
2009-03-29NetStar: update crcit utilityLadislav Michl
Make crc32 function to match its prototype. Use more meaningful identifiers. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-02-14Update board NetStarPeter Pearse
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-10-28[PATCH] Add some missing machtypes for netstar & voiceblue boardsStefan Roese
Use MACH_TYPE_NETSTAR and MACH_TYPE_VOICEBLUE defines instead of numbers in code. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-09Coding style cleanupWolfgang Denk
2006-09-01Remove the board/netstar/crcit binary from git repository.Marian Balakowicz
2006-07-21Code cleanupWolfgang Denk
2006-07-21Update NetStar boardWolfgang Denk
Patch by Ladislav Michl, 03 Nov 2005
2006-04-12Merge with /home/m8/git/u-bootWolfgang Denk
2006-04-08Fix JFFS2 support for legacy NAND driver.Marian Balakowicz
Some more NAND cleanup and small fixes.
2006-03-12Fix cleanup for netstart board.LABEL_2006_03_12_0025Wolfgang Denk
Remove build results from repository
2006-03-11Some code cleanup for GCC 4.xWolfgang Denk
2006-03-06Minor code cleanupWolfgang Denk
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2006-02-24Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling.Bartlomiej Sieka
