path: root/board/netstal
2008-09-08ppc4xx: Move ppc4xx specific prototypes to ppc4xx headerStefan Roese
This patch moves some 4xx specific prototypes out of include common.h to a ppc4xx specific header. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-11Fix some more printf() format issues.Wolfgang Denk
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Complete remove bogus dflush()Stefan Roese
Since the current dflush() implementation is know to have some problems (as seem on lwmon5 ECC init) this patch removes it completely and replaces it by using clean_dcache_range(). Tested on Katmai with ECC DIMM. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-16Conding style cleanupWolfgang Denk
2008-03-15ppc4xx: program_tlb now uses 64bit physical addessStefan Roese
This patch changes the physical addess parameter from 32bit to 64bit. This is needed for 36bit 4xx platforms to access areas located beyond the 4GB border, like SoC peripherals (EBC etc.). Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add 405GPr based MCU25 board specific filesNiklaus Giger
Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-03-15ppc4xx: HCU4/5. remove obsolete hcu_flash.cNiklaus Giger
2008-03-15ppc4xx: HCU4/5. Use FLASH_CFI_LEGACYNiklaus Giger
Cleanup: Remove custom flash driver for 8 bit boot-eprom and replace it with the FLASH_CFI_LEGACY et al. config options. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-24Coding style cleanup. Prepare v1.3.2-rc2 release candidatev1.3.2-rc2Wolfgang Denk
2008-02-16ppc4xx: HCU4/5. CleanupsNiklaus Giger
- Fix some coding style violations. - Use in/out_u16/32 where appropriate. - Use register names from ppc405.h. - Fix trace useage for Lauterbach. - Remove obsolete generation HCU2. - Renamed fixed_hcu4_sdram to init_ppc405_sdram. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-14ppc4xx: HCU4/5. Fix make O=../xxNiklaus Giger
2008-01-23Coding Style Cleanup; update CHANGELOGWolfgang Denk
2008-01-17ppc4xx: Fix compilation warnings and coding style issues in HCU4/HCU5Stefan Roese
2008-01-17ppc4xx: Netstal HCU4 board: added various fixes and POSTNiklaus Giger
- Moved some common code to netstal/common/nm_bsp.c. - sdram initialisation goes go netstal/common/fixed_sdram.c. - Added support for POST. - Stylistic cleanups (multi-line comments/ enforce 80 colomn width) Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: netstal/common define routines used by all boardsNiklaus Giger
Added some routines used by all Netstal boards: - nm_bsp.c: - nm_show_print and - common_misc_init_r - set_params_for_sw_install. Very specific code to handle our SW installation procedure - fixed_sdram.c: Common routines for HCU4 (and upcoming) MCU25 boards to handle sdram initialization. - nm.h: Common header Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: Netstal HCU5 board: added various fixes and POSTNiklaus Giger
- Moved some common code to nestal/common/nm_bsp.c. - Added support for the vxWorks EDR. - Enable trace for Lauterbach, if present. - Added support for POST. - Stylistic cleanups (multi-line comments/ enforce 80 colomn width) Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: Netstal HCU5 board. Added POST. Various fixesNiklaus Giger
- Various fixes - Reduced rom_size from 384 to 320 kB - Environment is now in flash - Added POST - Support for OF Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: Netstal HCU4 board. Added POST. Various fixesNiklaus Giger
2007-10-31ppc4xx: Consolidate some of the 405 and 440 macros/structs into 4xxStefan Roese
This patch moves some common 4xx macros and the PPC405_SYS_INFO/ PPC440_SYS_INFO structure into the common ppc4xx.h header. Lot's of other macros are good candidates to be consolidated this way in the future. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-18Merge with git+ssh://gemini_vpn/home/wd/git/u-boot/masterWolfgang Denk
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16PPC4xx:HCU4/5 cleanupNiklaus Giger
Minor cleanups to confirm to the u-boot coding style. Some german expressions -> english. HCU5 enforces a unique IP adress for a given slot in the rack. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-08-16PPC4xx:HCU4/5 cleanup ecc/sdram initNiklaus Giger
Make ecc initialisation robust, as DDR2-ECC errors may be generated while zeroing the RAM. Return 16 bytes (a cacheline) less than the available memory, as the board and/or PPC440EPx might have problems accessing the last bytes. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-08-15PPC4xx:HCU4/5-Board fix compile warningNiklaus Giger
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10Coding style cleanupStefan Roese
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: HCU5 filesNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: HCU4 filesNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: common filesNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: make relatedNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: READMEsNiklaus Giger
