path: root/board/netstal/hcu4
2008-06-03ppc4xx: Remove superfluous dram_init() call or replace it by initdram()Stefan Roese
Historically the 405 U-Boot port had a dram_init() call in early init stage. This function was still called from start.S and most of the time coded in assembler. This is not needed anymore (since a long time) and boards should implement the common initdram() function in C instead. This patch now removed the dram_init() call from start.S and removes the empty implementations that are scattered through most of the 405 board ports. Some older board ports really implement this dram_init() though. These are: csb272 csb472 ERIC EXBITGEN W7OLMC W7OLMG I changed those boards to call this assembler dram_init() function now from their board specific initdram() instead. This *should* work, but please test again on those platforms. And it is perhaps a good idea that those boards use some common 405 SDRAM initialization code from cpu/ppc4xx at some time. So further patches welcome here. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-16Conding style cleanupWolfgang Denk
2008-03-15ppc4xx: HCU4/5. Use FLASH_CFI_LEGACYNiklaus Giger
Cleanup: Remove custom flash driver for 8 bit boot-eprom and replace it with the FLASH_CFI_LEGACY et al. config options. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-16ppc4xx: HCU4/5. CleanupsNiklaus Giger
- Fix some coding style violations. - Use in/out_u16/32 where appropriate. - Use register names from ppc405.h. - Fix trace useage for Lauterbach. - Remove obsolete generation HCU2. - Renamed fixed_hcu4_sdram to init_ppc405_sdram. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-02-14ppc4xx: HCU4/5. Fix make O=../xxNiklaus Giger
2008-01-17ppc4xx: Fix compilation warnings and coding style issues in HCU4/HCU5Stefan Roese
2008-01-17ppc4xx: Netstal HCU4 board: added various fixes and POSTNiklaus Giger
- Moved some common code to netstal/common/nm_bsp.c. - sdram initialisation goes go netstal/common/fixed_sdram.c. - Added support for POST. - Stylistic cleanups (multi-line comments/ enforce 80 colomn width) Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: Netstal HCU4 board. Added POST. Various fixesNiklaus Giger
- Various fixes - Reduced rom_size from 384 to 320 kB - Environment is now in flash - Added POST - Support for OF Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-08-16PPC4xx:HCU4/5 cleanupNiklaus Giger
Minor cleanups to confirm to the u-boot coding style. Some german expressions -> english. HCU5 enforces a unique IP adress for a given slot in the rack. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-08-15PPC4xx:HCU4/5-Board fix compile warningNiklaus Giger
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10Coding style cleanupStefan Roese
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: HCU4 filesNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: make relatedNiklaus Giger
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: READMEsNiklaus Giger
