path: root/board/netstal/common/nm.h
2008-02-24Coding style cleanup. Prepare v1.3.2-rc2 release candidatev1.3.2-rc2Wolfgang Denk
2008-02-16ppc4xx: HCU4/5. CleanupsNiklaus Giger
- Fix some coding style violations. - Use in/out_u16/32 where appropriate. - Use register names from ppc405.h. - Fix trace useage for Lauterbach. - Remove obsolete generation HCU2. - Renamed fixed_hcu4_sdram to init_ppc405_sdram. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: netstal/common define routines used by all boardsNiklaus Giger
Added some routines used by all Netstal boards: - nm_bsp.c: - nm_show_print and - common_misc_init_r - set_params_for_sw_install. Very specific code to handle our SW installation procedure - fixed_sdram.c: Common routines for HCU4 (and upcoming) MCU25 boards to handle sdram initialization. - nm.h: Common header Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
