path: root/board/nc650
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Remove white space at end.William Juul
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2007-07-09board/[m-p]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-04-20Cleanup compiler warnings, update CHANGELOGWolfgang Denk
2007-04-20Fix breakage of NC650 board with respect to nand support.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-05-03Coding Style cleanupWolfgang Denk
2006-04-19Added missing nand.c for NC650 boarddzu@denx.de
Signed-off-by: dzu@denx.de <dzu@eddie.localdomain>
2006-04-19Update for NC650 board. Add NC650 based CP850 configuration.dzu@denx.de
Signed-off-by: dzu@denx.de <dzu@denx.de>
2005-03-14Patch by Detlev Zundel, 14 Mar 2005:wdenk
NC650: changed NAND flash addressing to using UPMB
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-11* Enable NAND flash support for NC650 board.wdenk
* Patch by Thomas Lange 07 Oct 2004: Updated README for DBAu1x00 boards to match current status
2004-08-28Add support for IDS "NC650" boardLABEL_2004_08_29_0045wdenk
