path: root/board/nc650/u-boot.lds.debug
2010-10-19NC650/CP850: remove code for yet another corpseWolfgang Denk
The NC650 / CP850 boards have long been unmaintained and left broken. As obviously nobody is interested in that code any more, we may as well remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2004-08-28Add support for IDS "NC650" boardLABEL_2004_08_29_0045wdenk
