path: root/board/mx31ads
2008-05-10mx31ads: fix 32kHz clock handlingGuennadi Liakhovetski
According to schematics and to RedBoot sources, the MX31ADS uses a 32768Hz oscillator as a SKIL source. Fix previously wrongly assumed 32000Hz value. Also fix a typo when verifying a jumper configuration. While at it, make two needlessly global functions static. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-24i.MX31: Fix architecture numbers for ADS and Litekit boardsMagnus Lilja
Correct the Linux architecture number for i.MX31 Litekit and ADS boards. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-04-24MX31ADS environment variable update, spi and rtc supportGuennadi Liakhovetski
Update MX31ADS default environment to better match the flash layout and the memory map, support SPI and RTC. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-18MX31ADS network and flash updatesGuennadi Liakhovetski
This patch allows U-Boot to use buffered writes to the Spansion NOR flash installed on this board, and eliminates long delays in network transfers after the board startup. Also modify flash layout to embed main and redundant environment blocks in the U-Boot image. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-18Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
