path: root/board/musenki
2008-09-02Moved initialization of TULIP Ethernet controller to board_eth_init()Ben Warren
Affected boards: cu824 bab7xx adciop dasa_sim mousse mpc8540eval musenki mvblue pcippc2/pcippc6 sbc8240 stxssa Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-07-04Remove obsolete mpc824x linker scripts (3 of 4)Grant Likely
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-04-01Initial revisionwdenk
2001-12-15Initial revisionwdenk
