path: root/board/musenki
2007-07-04Remove obsolete mpc824x linker scripts (3 of 4)Grant Likely
2003-02-14Add "pcidelay" environment variable (in ms, enabled via CONFIG_PCI_BOOTDELAY).stroese
2002-08-14Initial revisionwdenk
2002-04-01Initial revisionwdenk
2001-12-15Initial revisionwdenk
