path: root/board/munices
2016-05-27Delete tests of CONFIG_OF_LIBFDT when testing CONFIG_OF_BOARD_SETUPRobert P. J. Day
Since CONFIG_OF_BOARD_SETUP depends on CONFIG_OF_LIBFDT: config OF_BOARD_SETUP bool "Set up board-specific details in device tree before boot" depends on OF_LIBFDT ... remove superfluous tests of CONFIG_OF_LIBFDT when testing for CONFIG_OF_BOARD_SETUP. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> [trini: Typo fix: s/ifdefi/ifdef/] Signed-off-by: Tom Rini <trini@konsulko.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2011-04-30Handle most LDSCRIPT setting centrallyScott Wood
Currently, some linker scripts are found by common code in config.mk. Some are found using CONFIG_SYS_LDSCRIPT, but the code for that is sometimes in arch config.mk and sometimes in board config.mk. Some are found using an arch-specific rule for looking in CPUDIR, etc. Further, the powerpc config.mk rule relied on CONFIG_NAND_SPL when it really wanted CONFIG_NAND_U_BOOT -- which covered up the fact that not all NAND_U_BOOT builds actually wanted CPUDIR/u-boot-nand.lds. Replace all of this -- except for a handful of boards that are actually selecting a linker script in a unique way -- with centralized ldscript finding. If board code specifies LDSCRIPT, that will be used. Otherwise, if CONFIG_SYS_LDSCRIPT is specified, that will be used. If neither of these are specified, then the central config.mk will check for the existence of the following, in order: $(TOPDIR)/board/$(BOARDDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/$(CPUDIR)/u-boot-nand.lds (only if CONFIG_NAND_U_BOOT) $(TOPDIR)/board/$(BOARDDIR)/u-boot.lds $(TOPDIR)/$(CPUDIR)/u-boot.lds Some boards (sc3, cm5200, munices) provided their own u-boot.lds that were dead code, because they were overridden by a CPUDIR u-boot.lds under the old powerpc rules. These boards' own u-boot.lds have bitrotted and no longer work -- these lds files have been removed. Signed-off-by: Scott Wood <scottwood@freescale.com> Tested-by: Graeme Russ <graeme.russ@gmail.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-05-14Fix config files for out-of-tree buildingWolfgang Denk
Several board/<...>/config.mk files include dynamically built (by the Makefile) config files but used the wrong file name of $(TOPDIR)/board/$(BOARDDIR)/config.tmp instead if the correct $(OBJTREE)/board/$(BOARDDIR)/config.tmp The bug is nasty because the build result is correct for the (normal) in-tree builds, and because 'sinclude' is used no errors get raised even for out-of-tree build tests. But out-of-tree builds use an incomplete and thus usually incorrect configuration... Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-01-13MUNICes: fix board Makefile for remote build directoryWolfgang Denk
2008-01-12added basic support for the MUNICes board.Heiko Schocher
