The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com>
Tested-by: Heiko Schocher <hs@denx.de>
Remove Ethernet node fixup from mgcoge and muas3001 boards and modify its
configs for the common mpc8260 code to use generic Ethernet fixup.
Acked-by: Heiko Schocher <hs@denx.de>
The boards that get converted here to use the environment for the mac
address rather than global data:
debris
mgcoge
mgsuvd
muas3001
netstal
pn62
sixnet
vcma9
xilinx (the ones that use xilinx_enet)
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Sangmoon Kim <dogoil@etinsys.com>
CC: Heiko Schocher <hs@denx.de>
CC: David Mueller <d.mueller@elsoft.ch>
CC: Niklaus Giger <niklaus.giger@netstal.com>
CC: Wolfgang Grandegger <wg@denx.de>
CC: Dave Ellis <DGE@sixnetio.com>
CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
Also set up the port pins for using I2C.
