path: root/board/muas3001/muas3001.c
2009-11-22mpc8260: move FDT memory node fixup into common CPU code.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Tested-by: Heiko Schocher <hs@denx.de>
2009-09-15mpc8260: remove Ethernet node fixup to use generic FDT code.Marcel Ziswiler
Remove Ethernet node fixup from mgcoge and muas3001 boards and modify its configs for the common mpc8260 code to use generic Ethernet fixup. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Tested-by: Heiko Schocher <hs@denx.de>
2009-09-10muas3001: remove BRG clock node fixup to use common mpc8260 code.Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@noser.com> Acked-by: Heiko Schocher <hs@denx.de>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2008-09-10muas3001: update BR4 settingsHeiko Schocher
Also set up the port pins for using I2C. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-10muas3001: added 64MB SDRAM autodetection.Heiko Schocher
2008-08-27Add support for muas3001 board (MPC8270)Heiko Schocher
