Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
This header file should not be included in other header files. Remove it
from each one and use a forward declaration instead.
Move this uncommon header out of the common header.
Move this header out of the common header.
A number of board function belong in init.h with the others. Move them.
This header file is now only used by files that access internal
environment features. Drop it from various places where it is not needed.
Implement method board_phy_config to configure the external phys
on the pcb90.
Signed-off-by: Horatiu Vultur <horatiu.vultur@microchip.com>
Implement method board_phy_config to configure the phy for pcb120.
In Serval SoC family there are 2 different pcb, both of them have the same
phy, but with different version. Therefore implement board_phy_config
and set all the phys in the same way.
When detecting the board, it was reading a register in the GPIO page of
the phy and based on that value it was making a decision. The bug was that
after the GPIO page for the first phy was set it was not reseted back.
In Jaguar2 SoC family there are 3 different pcb. Each of this needs
to configure the phys in different ways. Therefore implement the
function board_phy_config and based on pcb configure them accordingly.
When power cycle the Jaguar2 boards, it couldn't read the
phys, therefore it always deduce that the board type is
pcb111.
Add a small delay after setting the gpio pins, fix the
issue.
Enable debug uart for Jaguar2 SoC family.
Add board support and configuration for Jaguar2 SoC family.
The detection of the board type is based on the phy ids.
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Add board support, configuration and DTS for Servalt SoC
family. Currently there is one board in this family.
On some ocelots platform a workaround is needed in order to be able to
reset the switch without resetting the DDR.
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Add board support and configuration for Jaguar2 SOC family.
The detection of the board type in this family is based on the phy ids.
This enables the use of the MSCC serial GPIO driver to control the
LEDs on the MSCC VCoreIII 'ocelot' pcb123 and pcb120.
Signed-off-by: Lars Povlsen <lars.povlsen@microchip.com>
LEDs on the MSCC VCoreIII 'luton' SoC.
As we are moving to multi-dtb and board detection, remove static board
config options, and introduce board probing instead.
Luton: This add single-binary support for the two MSCC luton-based
reference boards - pcb090 and pcb091. The SoC chip ID is used to
determine the board type.
Ocelot: This add single-binary support for the two MSCC ocelot-based
reference boards - pcb120 and pcb123. The PHY ids on specific ports
are used to determine the board type.
Adding the support for the Luton boards PCB91 which share common code with
the Ocelots boards, including board code, device tree and configuration.
Adding the support for 2 boards sharing common code for Ocelot chip:
PCB120 and PCB123
